Results 1 to 20 of 32
Thread: OMG how screwed em I?!
06-30-2010, 12:30 PM #1
Idk if i just did this with the jack! i Put it in the center! and i cant say i know if the dent was there in the first place! The car dont make any strange noises..and it drives normal..took it around the block..Am i screwed? D'=
http://s787.photobucket.com/albums/y...emberdent2.jpg
http://s787.photobucket.com/albums/y...erdent1.jpg%26
06-30-2010, 12:34 PM #2
I not sure but I think that was already there. Doesn't look horrible but something to keep an eye out. i'm sure some of the more experienced guys will have more input about.
06-30-2010, 12:35 PM #3
Hm...god i hope so..i was just trying to jack my car so i can chane the oil =(..and i tried jacking from where i could best guess from the picture on installuniversity..
1992 Black/Gold Bandit Style Firebird (Retired)
1998 Blue/Green Formy A4 (Gone)
2002 Dark Blue Trans Am A4 (Daily Drive)
06-30-2010, 12:48 PM #4
I agree that it looks pre-existing.
06-30-2010, 12:50 PM #5
So pajeff....think im okay?? =(..if so..where can i jack the front end up to change the oil?? I dont have the option of ramps right now.
06-30-2010, 12:50 PM #6
x3 on already there.....
06-30-2010, 12:51 PM #7
Okay..so am i alright?? How bad would it be to fix it??
06-30-2010, 12:53 PM #8
i dont think u need to fix it.....get a pic looking straight up at it
06-30-2010, 12:54 PM #9
also, just a tip to help you out....if you copy and paste the IMG code from photobucket the pics will appear in the thread rather than having to click each one to view it
06-30-2010, 01:02 PM #10
its hard to get a good picture..hope this helps?
06-30-2010, 01:03 PM #11
that hole is the hole you see in the other pictures with the dent
06-30-2010, 01:05 PM #12
Thats..not even the k member is it?..fuc* ='(
06-30-2010, 01:09 PM #13
Also..i didnt lift the car i just did a few cranks and dropped it as soon as i moved angels and saw that dent.
06-30-2010, 01:14 PM #14
The k-member is a fairly rugged piece. I don't think you'll do any further harm jacking it from there.
06-30-2010, 01:16 PM #15
So...bottom line am i okay?
06-30-2010, 01:18 PM #16
06-30-2010, 01:19 PM #17
Whew..okay so to double check that IS the k member right? should i put a 2x4 on the jack plate or whatever?
06-30-2010, 01:43 PM #18
You're good.. Imho maybe the previous owner got stuck and used the hole to hook the chain/cable to.. That area is designed to take a beating.. No worries.
06-30-2010, 01:48 PM #19
yeah that doesnt look from you jacking the car up. If the car run fine and is not out of alignment or stuff like that i will leave it alone. trying to get that fix can cause more trouble.
I just jack the car from the drivers side by the chassis area and that gives me enough clearance to put a jack stand (for safety ) and to change my oil.
the only thing now is that i put my 2 point SFC and Im not sure if I can use that area anymore.
06-30-2010, 01:55 PM #20
That is a tooling relief hole, and the piece is stamped out of heavy guage steel @ tens of thousands of psi. Rest assured your cars weight in concert with jacking is'nt enough to damage it..
Am I Screwed??
By rajiv1998 in forum Almost Anything GoesReplies: 17Last Post: 10-22-2010, 04:06 AM -
Help: I'm screwed, right?
By dgoett in forum DrivetrainReplies: 7Last Post: 07-20-2010, 07:18 PM -
So am I screwed?
By burnws6 in forum Almost Anything GoesReplies: 94Last Post: 07-31-2007, 05:21 AM -
Screwed
By silver98TA in forum General HelpReplies: 9Last Post: 05-28-2007, 10:50 AM -
I'm screwed......
By HASTINGSRJ in forum Western MembersReplies: 18Last Post: 08-18-2005, 02:47 PM
