Thread: who has the mufflex bump stop?
07-14-2007, 10:38 AM #1
I'm getting my headers and ory soon. people say there could be a problem with the y pipe banging under the car and the mufflex bump stop hanger will stop this. I'd like to save the $40 and not have to buy it if it doesn't bang. how many of you guys had this problem?
07-14-2007, 10:41 AM #2
- Dec 2002
- n/w chicago
if the y pipe bangs, heat it up with a torch and bend alittle, problem solved
a few bolt ons, 379 rwhp
11.96 @113.25
07-14-2007, 12:06 PM #3
Got it when the the QTP LT's & ORY went in. What's another $40 for piece of mind..........................
2002 SLP Camaro SS
Onyx Black
http://www.gmhightechperformance.com/features/0901gmhtp_2002_chevy_camaro_ss/index.html
07-14-2007, 03:59 PM #4
You don't have to get the Bump Stop. If you are taking it to a shop of even at home, you can weld a L-bracket onto the y-pipe and install a slotted hanger to the unitized frame. That is off course if you have a welder.
I have QTP LTH's and Pacesetter Y-pipe and have no issues with it hitting the floor board. It is a matter of getting it aligned correctly. Although, then again you may need it.
You can install the LTH's and Y-pipe without the Bump Stop. If it hits, you can always install it latter down the road.Last edited by 9t8z28; 07-15-2007 at 05:24 AM.
07-14-2007, 08:14 PM #5
or just stick a piece of heater hose in between the car and pipe. lots of people have done that w/o problems.
07-14-2007, 10:13 PM #6
Thanks for the tips. Looks like I'm gonna have to wait and see how everything turns out.
07-14-2007, 11:59 PM #7
With my pacesetter and ory instail i have alot of bumping issues, i heated up the pipe and bent it down, didnt work, cut out a seciton of the pipe and welded in a new piece, worked better but not completely, then instailed the bumpstop and havent heard a peep since.
All sugestions above are good ones thou.
07-15-2007, 08:06 AM #8
- Aug 2006
- maryland
yellow- 2002 trans am
The bumpstop worked well for me until about 500 miles then the metal bracket broke in half. bought a new one and it did it again. So what i did was buy poly motor mounts and It is fixed. The reason why it bangs is because when the motor torque's up it takes the driver side pipe up with it and it bangs against the floor board. so the poly motor mounts keeps it from doing that.
TB Bump Stop Mod
By bhunter0830 in forum General HelpReplies: 9Last Post: 09-07-2012, 10:50 AM -
For Sale: GMPP ASA CAM, LS6 Springs, Mufflex Bump Stop
By hoss 2000 z-28 in forum Parts For Sale / TradeReplies: 2Last Post: 09-14-2009, 05:52 PM -
Mufflex bump stop hanger doesn't fit
By GottaHaveLS1 in forum General HelpReplies: 2Last Post: 08-25-2007, 02:12 PM -
Bump Stop Mod
By KM02SS in forum External EngineReplies: 14Last Post: 09-12-2006, 06:45 PM -
By Pete Rock98 in forum Parts ReviewReplies: 8Last Post: 03-21-2006, 05:00 PM
