Results 1 to 20 of 33
08-11-2007, 09:05 AM #1
- Nov 2006
- Hammond, Louisiana
Collector Yellow (54U)- 2002 Trans Am CE
HOW TO: Replacing a Broken Seat Belt Guide
Made this write up with pictures to help anyone who has a cracked or broken seat belt guide with the easiest way of replacing it. Sure it's not a highly difficult job, but it will help out those with little or no mechanical know how.
First I'll start off with a rundown of the part numbers of the different seat belt guides* for the different interior colors:
seat shoulder belt guide (98-02), neutral, RH = 16789714
seat shoulder belt guide (98-02), neutral, LH = 16789715
seat shoulder belt guide (98-02), gray, RH = 16799272
seat shoulder belt guide (98-02), gray, LH = 16799273
seat shoulder belt guide (98-02), pewter, RH = 16799274
seat shoulder belt guide (98-02), pewter, LH = 16799275
seat shoulder belt guide (98-02), ebony, RH = 16817200
seat shoulder belt guide (98-02), ebony, LH = 16817201
*Thanks to ACW of LS1tech for the list.
As far as tools that you will need:
-Philips head screwdriver
-Flat head screwdriver (small)
-3/8 inch drive socket wrench
-T50 Torx (Star) socket bit
If you don't have the Star sockets, a small set can be purchased at Autozone for $10. Here is the one I bought and worked perfectly
So, what do you do when your seatbelt guide breaks off? Well, only one thing to do really and that is replace it with a new one. Repairing the old one might work for a small frame of time, but its not recommended
Here is my broken seat belt guide hanging free from its rightful place on the headrest.
First step is putting on the new seat belt guide to the headrest. Doing this first will aid in not getting confused as to which way the guide goes onto the belt.
Just undo the screws with the philips head screwdriver. Make sure the head of the driver fits snug in the screws to avoid stripping.
Place the guide over the indented area in the leather of the headrest and find the hole with the top screw first. Screw that one it halfway and then put the bottom screw in. Tighten down both until the guide is snug and there is no play(back and forth motion). If it is not tightened down all the way, it will most likely break sooner than you like.
Next we move to removing the seat belt itself from its anchor position on the floor of the car.
Grab your small flat head screwdriver and GENTLY pry up the round plastic cover from the seat belt anchor. The plastic is very pliable as long as you remove it slowly.
Set aside the cover for replacement at the end of the changeover. Here you can see the underside of the cover and notice the notch in it that allows you to slip one side back under the anchors plastic cover and screw it back into its home position.
Now grab your socket wrench and put on the T50 bit. Make sure the bit is all the way into the bolt and snug. Do Not Try to Wrench it quickly. Start with a little pressure and slowly add more to the turn while keeping the bit pressed into the bolt to avoid stripping. Mine wasn't Super tight, but some might be tighter than others. Just take you time and it will come loose.
After loosening and removing the anchor bolt, just slide the broken seat belt guide off of the seat belt.
Take the end of the seat belt and run it through the guide that is attached to the headrest.
Next, slip the seat belt buckle through the guide at an angle.
Now, check and make sure that there are no twists in the belt and that it lays flat by buckling the belt in and test fitting it.
with the belt still buckled in, replace the anchor end and put the bolt back in and tighten as much as you can but do not overtighten. You'll feel the bolt stop at a point.
If you have a torque wrench, set if for 31 foot lbs. and wrench the bolt down with a little lock tite on the threads. (tip by Smkn_TA)
Now just replace the round cover to the anchors plastic cover by setting one side of the groove into the opening and turning it to set in place. That is it, you're done. Enjoy your non-neck chaffing seat belt.
2002 Trans Am Collector Edition WS6 ASC# 619
Coupe | Collector Yellow on Ebony Leather | A4 | TCS | #126 of 510 T-Top w/A4 made
CETA 619 "The Falcon"
Collector Edition Owner Site: www.collectorfbody.com
08-11-2007, 09:19 AM #2
- Jul 2005
- Jacksonville, FL
Good job! I've seen where people bought the convertible guide cause it's a little easier to install - but not as strong and the coupe units.
08-11-2007, 09:41 AM #3
- Nov 2006
Yes, I was thinking about using the Vert guides but I also read about how the belt likes to slip out of the guide more than it should. So I opted for the original.
If you want to make the replacement 90% easier, then get the Vert guides. Sorry fellas, don't have the part numbers for those, but if someone wants to gather them up I'll add them to the original post.
08-12-2007, 08:52 AM #4
nice write-up. you get a sticky.
08-12-2007, 06:59 PM #5
- Nov 2006
Sweet, I got a sticky!
08-13-2007, 05:07 AM #6
- May 2007
- Davenport, Iowa
Bright Red- 1999 Trans Am Ws6
You couldn't write this five days sooner!??!?! I had to do it twice, cause I was not smart enough to attatch the guide first. Damn it! Oh, put lock tite on the anchor bolt, and use a torque wrench and set it to 31 foot lbs. Son of a bitch though...attatch guide first. Brilliant!!!
08-14-2007, 07:34 PM #7
- Nov 2006
Sorry bout that.
When I was researching how other people had done this most all of them had problems getting the guide on the right way because they would put it on after the fact. So I just thought, why not attach it first and run the belt through...seemed like it would be SOOO much easier that way...and it was!
I'll add that info that you put to the write up.
08-16-2007, 10:10 AM #8
- Mar 2007
- NC
NBM- 1998Z28
I took a dremel with a diamond wheel and cut a slit thru mine slipped my seatbelt thru and glued the slit closed with JB Weld which was the same color as my seatbelt loop. Unless your looking for it you don't see it. I could use the Part #s for the two phillips screws. I have one missing and haven't been able to find one the same size.
09-15-2007, 03:22 PM #9
- Pittsburgh, PA
which side is the "driver's side" right or left?
09-15-2007, 11:23 PM #10
09-16-2007, 12:23 PM #11
- Pittsburgh, PA
i wouldn't have asked if i were
09-23-2007, 07:36 PM #12
- Jul 2006
- Sunnier Yuma Ariz
Navy Blue- 2001 Trans Am WS6 Vert
Vert Belt Guides
Would like to also know what the Vert # are. I ordered them from the dealer. twice I received the solid set. Dealer said to cut a slot in them, these were the only ones GM makes. I told them I can see the mold marks on the slot. They would not budge.
Thanks to you who finds them.
10-28-2007, 09:11 AM #13
- Sep 2007
- Lockport, NY
Black- 99 Trans am Convertible
good write up, i was afraid i was going to break that little plastic plug until i read this, thanks. drivers side is the left.
10-28-2007, 09:30 AM #14
Good writeup, but I was hoping it would explain how to fix the seatbelt guide after it has been pulled out of the side of the headrest. The screw holes are all stripped out and the material is ripped up, it was like that when I bought the car.
10-29-2007, 04:08 PM #15
- Jun 2007
- Florida
Oriental Blue- 2001 Trans Am WS.6 M6
excellent write up man, im gonna go take care of this now, i just assumed they had slots then i screwed in the new loop and went to put in the belt and was like
10-30-2007, 03:07 PM #16
- Sep 2007
- Lockport, NY
oh and the bit wasnt t 50 for mine, it was a size smaller
10-30-2007, 06:33 PM #17
- Jun 2007
- Florida
11-04-2007, 07:55 AM #18
- Aug 2006
- St. Louis
great writeup, took me 3 minutes to do =)
05-23-2008, 04:46 PM #19
Worked awesome!!! Thanks. The hardest part was realizing that I didn't have the T-50 and borrowing one...hahhah. Great Job!!!
10-10-2008, 04:32 PM #20
WTB seat belt guide black and CAI
By sasquatch094 in forum Parts Wanted / TradeReplies: 2Last Post: 03-30-2010, 06:59 AM -
Seat belt guide
By Z28_Driver in forum Camaro / SSReplies: 7Last Post: 01-21-2010, 12:38 PM -
broken seat belt piece
By n8man8 in forum General HelpReplies: 5Last Post: 01-30-2008, 12:32 PM -
replacing seat belt guide
By Formula_LS1 in forum Firebird / WS6Replies: 6Last Post: 03-18-2007, 11:24 AM -
replacing the seat belt guide loop(99 TA)
By coleman in forum Firebird / WS6Replies: 5Last Post: 04-09-2006, 08:12 PM
