Thread: ses codes
    Feb 2008
    jupiter fl.
    2000 trans am
    ses codes
    what would set a rich bank two code and also security light is on 2000 ws6 with deletes and new o2s,frost tune thanks
    98 T/A w/ mods, 00 FBVert
    can you give the code #?
    Feb 2008
    jupiter fl.
    2000 trans am
    the code was cleared and my reader doesn't have a history,it just said bank 2 rich,
    and now the security light is on
    Most likely those are completely unrelated issues. Any work been done on the car recently?
    Feb 2008
    jupiter fl.
    2000 trans am
    yes frost tune with deletes,lth,s y-pipe,flowmaster plugs(ngk) msd wires,had rich bank 2 code after mods cleared it was fine for a week or two then check engine light came back on I checked it and again rich bank 2cleared it again, its been off (check engine light) for a few days,maybe it gets loaded up driving around town idk.
    what can I check to see why the security light is on an why doesn't that set a code thanks
    Bank 2 is the passenger side so you could always pull and compare plugs to see if you have an actual rich condition. You can also swap your front O2 senders side to side and see if the code follows the sensor, or if it stays on Bank 2. Is your air filter clean and unobstructed? Throttle body clean?
  1. what do these codes mean
    By jb007 in forum General Help
    Last Post: 05-19-2010, 06:32 PM
  2. codes
    By camaro00ss in forum General Help
    Last Post: 03-31-2008, 10:14 AM
  3. no RPO codes
    By deepblackz in forum Camaro / SS
    Last Post: 11-06-2007, 07:56 AM
  4. What do these codes mean. PLEASE HELP
    By ram air ws6 in forum General Help
    Last Post: 02-23-2007, 05:34 PM
  5. New and I need some help with SES codes.
    By mczerwonka in forum General Help
    Last Post: 01-28-2007, 07:46 AM
