Results 1 to 20 of 36
    HiLL99SS
    Guest
    Which Aftermarket Rotors?
    I was wondering which brands of rotors everyone is running, and what style
    DRILLED/SLOTED, DIMPLED/SLOTED, ect. Also what are some of the price ranges of some of these. I am looking for the Front and Rear. Thanks fellas
    Retired Outlaw Sum Bitch
    I'll catch all kinds of "Internet hell" for this...but you ask a simple question and I will answer you from experience and not what I read somewhere...fair enough?
    Drilled rotors often times crack from the drilled hole......slotted are good if properly matched with pads....BAER Brakes suck Donkey Balls and are very poor quality. Baer Brakes customer service has surpassed the lowest form of plankton life living on the bottom of the ocean floor under the whale shit.
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    C'mon Sarge-tell us what you really think!!!lmao
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    http://www.powerslot.com/pages/power_slot_app.html
    this is what i have, they were 125ea for the front and 100ea for the rear, look good, and good performance.
    HiLL99SS
    Guest
    What do you all think about dimpled/sloted rotors?
    What are some of the best brands?
    I have only been able to find the dimpled/sloted in one brand (Raceconcepts), its not a brand I have ever heard of. I was wondering if these will have any kind of the same affect as the DRILLED rotors with the cracking and stuff.
    HiLL99SS
    Guest
    What about pads, what are the better pads to use with these aftermarket rotors?
    HiLL99SS
    Guest
    I need 10 posts, heres the 10th
    Quote Originally Posted by HiLL99SS
    Hawk Hawk Hawk Hawk
    Hook Em Horns Baby
    HiLL99SS
    Guest
    cool deal those were the ones I had looked at the other day
    Sarge - Its good to see some Longhorn Fans around the forum - Hook Em'
    Member redz284u's Avatar
    Littlerock, CA
    1998 SS
    i'd say go with the powerslots, i went to local autoparts store and decided not to wait for the delivery of the powerslots and purchased a set of "preformance" drilled rotors i think "streetheat" is the maker, supposadly made from baer blanks, well i've had them bout six months and they are full of heat spots, and beggining to warp......and there is no one who will resurface them because they are drilled, i've never heard of negative feedback on powerslots.....the only way i would ever buy another set of drilled rotors is if i purchased a profesional set.
    pay a little more, get a little more is what im learning everytime i replace a part.....thats just my opinion
    98SS A4, TSP CLR LID, LS6 INTAKE, BMR SFC/STB/ LWR CNTRL & TRQ ARMS, KYB ADJ., HOTCHKINS SWAY BARS, MSD WIRES, JETHOT LT/ORY, MAGNAFLO CATBACK, EIBACH PROKIT, 19" TSW WHEELS, PERMA COOL TRANY COOLER.
    257.8 hp (MUSTANG-DYNO) b4 ANY MODS.
    13.6 1/4 mile
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    I have had very good luck with the Baer Eradispeed rotors coupled to Hawk HPS pads, a good idea also would be to replace your rubber brake hoses with Earls braided stainless steel lines.
    SteveC
    Awaiting Activation Liquifire's Avatar
    central wisconsin
    Quote Originally Posted by Sarge
    =Baer Brakes
    BBATCAR
    Guest
    Quote Originally Posted by SteveC
    SteveC
    I have Baer Rotors in the front, after 3 rotor replacements (different from Baer) because of warping. I have never had a problem with Baer Eradispeed and would recommend them... 15,000 miles so far and Baer have worked great for me...
    delinquent543
    Guest
    anyone have any experience with brembo rotors and/or brakes?
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    i have the wholesale direct rotors on mine and have no issues with them.
    Junior Member supermando's Avatar
    Albuquerque
    2002 Trans Am WS6
    Is there any advantage to changing the rear rotors? Most of the braking takes place in the front. I think.
    central wisconsin
    Most of the braking is up front but it will still benefit you to replace the rears as well...
    BlackHawk T/A
    Guest
    Can the brake balance be changed so the rears do more work?
    Wouldn't it make sense, physics wise? It would keep the nose from diving a little better...
    Junior Rocketeer jimmi7769's Avatar
    Russiaville, Indiana, United S
    Sunset Orange
    2001 Z28
    Quote Originally Posted by BlackHawk T/A
    No. Since most of the weight is transferred forward during braking all you'll end up doing by adding more rear power is lock up the rears a lot more often.
    If you want to eliminate brake dive you need stiffer springs.
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    i have willwood, from summit, cross drilled and sloted half and hald i love em, hope this helps jeremy
  1. Question: Aftermarket Name Brand Rotors
    By Agarcia67 in forum General Help
    Last Post: 03-03-2014, 02:21 PM
  2. Aftermarket pads and rotors help?
    By jdizzim in forum Firebird / WS6
    Last Post: 04-09-2012, 08:26 AM
  3. new rotors =D
    By blackbird0230 in forum Appearance Section
    Last Post: 08-28-2010, 08:57 PM
  4. Question: Need aftermarket rotors for Yukon
    By MrMasterCraft in forum GM Trucks
    Last Post: 02-28-2010, 08:24 AM
  5. Rotors
    By najaf4life in forum General Help
    Last Post: 10-25-2008, 04:45 AM
