Thread: Best Intake Manifold
03-28-2010, 08:37 AM #1
- Jan 2006
- Columbus, OH
Red- 2000 Trans AM
Trying to figure out what the best intake manifold is to put on my 2000 TA. I have seen where you can get the LS6 intake with provisions for like 450-500 bucks but then there is the intake manifold by FAST that sells for 800-900. I know that the mm size of the FAST intake is larger, but how much does that matter? Also if I got the larger intake manifold would i have to buy a larger MAF?
Thanks
03-28-2010, 09:08 AM #2
- Nov 2009
- NOVA
2002 C5 - M6 - Blue- 2000 Z28 - A4 - Pewter
+1 Wanted to get technical specifics on this as well. Is it the larger the cam, the larger the opening (mm) that's needed? And we know it's all about combination to make everything work at their best potential, sooo.... in the end, if you want power, you want to jam the most air and fuel into a given space and give it spark to combust it and make that power. Without upgrading to a larger cam, what intake/tb setup would you see the most gains out of? Would you need to upgrade the fuel pump and/or injectors as well, to see full potential out of any upgraded intake/tb?
I, myself, plan on eventually going with a cam that's lift is above .600" lift such as an MS4, TRex, or Tsunami
Not trying to just trying to further the questions, to get a little more of a detailed answer, instead of starting a new thread
2000 Z - Light Pewter Metallic - A4 - 130k - Bolt Ons - My Pride and Joy
2002 C5 - Electron Blue - M6 - 32k - My Dream Car
03-28-2010, 09:51 AM #3
For the cost, I went with the 90mm LS2 intake, plus had it ported. 90mm FAST TB and a 100mm MAF. The MAF is fun to get tuned...
03-28-2010, 01:18 PM #4
I just bought a used LS6 0ff a 2002 TA that someone was doing a FAst 90 setup on. Cost me $250. Check the forums for a used one usually can get one for $300 and under. Unless you plan on putting a big cam and some ported heads a LS6 woth a ported TB works great with a bolt on car and I know alot of people who run them with just a cam and a 100 shot.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
Intake Manifold
By 10erg01 in forum Parts Wanted / TradeReplies: 3Last Post: 01-20-2011, 04:55 PM -
Pro-Flo XT LS1 EFI intake manifold
By Alexander Abraham in forum External EngineReplies: 0Last Post: 05-26-2010, 08:55 AM -
LS6 intake manifold and 227 Intake runners
By IT_SS in forum Internal EngineReplies: 4Last Post: 07-07-2009, 02:11 PM -
WTB: Lt1 Intake Manifold
By Sphyr in forum Parts Wanted / TradeReplies: 0Last Post: 11-03-2007, 08:25 PM -
Intake manifold ?
By 99M6Z28 in forum External EngineReplies: 8Last Post: 01-22-2006, 11:55 AM
