Thread: 383 stroker
01-05-2015, 02:21 PM #1
383 stroker
I am building a lt1 383 stroker but before I start I wanted a good opinion on heads and cam combination
01-05-2015, 04:55 PM #2
- Jun 2011
- Branchville, NJ
It all depends on your goals. You can go from mild to wild and from weekend driver to full out drag racer. Your ultimate goal will determine what parts to put in the engine. Post your vehicle and purpose and you will get what you are looking for.
01-05-2015, 07:09 PM #3
383 stroker
some I can drive on the weekend but at the same time little street car I have a 1995 trans am
01-06-2015, 01:53 AM #4
Whoever you're getting the heads from is who you need to ask about a cam. When you know what heads you'll be using and what they flow, and what your ultimate power goals are, you can talk to your cam manufacturer.
01-07-2015, 07:44 AM #5
- Jun 2011
- Branchville, NJ
Put your HP and TQ goals on paper and call some vendors for ideas and parts. A good 383 stroker starts with a good bottom end. Don't skimp here. Good quality tri-metal bearings, a quality forged crankshaft, ARP bolts and studs, forged H-beam rods, forged aluminum pistons and file fit rings. And the most important part is the machine work, make sure it is done right. Add in a good oil pump and a roller timing chain and you are on your way to a fast, reliable engine. After you get your bottom end done you need to take some measurements on the deck height and piston height so that when you order your aluminum heads you will know what your CR is by factoring in you combustion chamber cc volume and your head gasket thickness. Shoot for around 9.5 to 10.2 for pump gas. Don't go too crazy with your cam choice but I would go with a roller cam and lifters as well as roller rockers. Crane makes good, affordable items to fit this need. Your rocker arm ratio will depend on your overall CR and cam choice, 1.6 or 1.7 is most common. After that you will need to make your intake choice either EFI or carb. last is a good set of headers, for a 383 stroker I would go with 1 7/8" if they fit your ride. You should come up with a reliable 450 - 500 hp engine. I hope this helps.
Question: 6.0 stroker
By speeedo in forum Internal EngineReplies: 6Last Post: 03-19-2008, 01:43 AM -
Stroker q
By grandkodiak in forum LT1Replies: 12Last Post: 02-28-2008, 08:53 PM -
Stroker kit on LS1?
By Wheeler99WS6 in forum Internal EngineReplies: 25Last Post: 03-24-2007, 07:15 PM
