Results 1 to 15 of 15
Thread: wheel bust!!
11-20-2011, 08:29 AM #1
wheel bust!!
Ok, I really have no clue at all what's wrong with my car now!! I'll hit the brakes and its like my rim(passanger front)will fall out of place and now my caliper is now rubbing against the rim....
11-20-2011, 09:36 AM #2
- Apr 2008
- Madison, WI
Pull the wheel off. I'm thinking the caliper is loose or missing a bolt
11-20-2011, 10:42 AM #3
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Agree with Cutlass.
11-20-2011, 03:55 PM #4
- Jan 2009
- North Jersey
Ditto.
11-20-2011, 04:22 PM #5
Ok, when it first happened and I tool the tire off, I tried moving the cal and it wouldn't budge. Cuz that's the first thing I thought of.. so it must be the wheel bearing rite??
11-20-2011, 04:29 PM #6
did you verify both bolts were in there? Just because you can't move it by hand doesn't mean a 3600 lb car coming to a stop won't move it. I bet you're missing a caliper bolt like was stated.
11-20-2011, 04:57 PM #7
11-20-2011, 05:30 PM #8
Yeah, I'm going to recheck it tomorrow after work. When I spin the tire I can hear a grinding sound from the cal. On the rotor. So it may very well be a broke bolt.
11-22-2011, 07:55 PM #9
- Jan 2009
- North Jersey
Well, hopefully the bolt isn't broken. Then you will have to do some drilling if the piece is still in the spindle.
11-24-2011, 02:22 PM #10
my friend i believe you had the same issue i had. Check the bolts that hold the caliper bracket. Not the caliper pins the 2 big 18mm (i think) bolts that are behind the bracket. Most likely you either loose/broke one or 2 off. In my case I lost one and was able to find it.
11-24-2011, 02:24 PM #11
this is the thread I made when it happened.
http://www.ls1.com/forums/f6/almost-bad-day-159204/
Be carefull because my wheel lock up completely when I was almost at full stop.
11-27-2011, 02:39 AM #12
^ wow, that happend to me with my 70 chevelle but it just clunked, lol, i think it was the other bolt tho...
11-27-2011, 10:59 AM #13
wonder if he's ever going to update the thread so we can learn what he found??
11-28-2011, 06:41 AM #14
Yeah, I'm updating it, Haha
Ended up being a bolt breaking and flying out. And because of the holiday the bolt won't be here til Wednesday, Haha
11-28-2011, 10:58 AM #15
cool, at least you got it figure out.
MN Gun Buy Back = Bust..
By SMWS6TA in forum Gun's & AmmoReplies: 10Last Post: 09-03-2016, 09:48 AM -
5,250 (rpm) AND bust!
By Whamhammer in forum General HelpReplies: 10Last Post: 09-24-2015, 08:30 PM -
Help: wheel bust?!
By Karczewski in forum Firebird / WS6Replies: 5Last Post: 11-20-2011, 04:24 PM -
Prepare to bust a nut
By JHayesLS1 in forum Almost Anything GoesReplies: 41Last Post: 11-28-2008, 10:23 AM
