Results 1 to 18 of 18
01-28-2011, 07:32 AM #1
- Dec 2006
- Winter Garden, FL
Black- 1999 Camaro Z28
Ordered some new parts, am I missing anything?
Yesterday, a day which will be forever referred to as legendary in my mind, I ordered
1) Longtube headers
2) TSP Y-pipe
3) SLP Lid
Am I missing anything to complete the install? I'm also deleting the EGR. Gonna make my own plates to shut it all up too.
01-28-2011, 08:11 AM #2
- cleveland ohio
trans am 00 ws6- 1998 camaro ss vert
gaskets for the headers should be able to use the stock ones. and band clamps for the exhaust.
01-28-2011, 08:43 AM #3
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Did you get new O2 sensors with the longer harness, or extensions for your existing ones?
01-28-2011, 11:28 AM #4
01-28-2011, 11:31 AM #5
- Mar 2007
- Henryetta/Tulsa Oklahoma
Band-aids for your knuckles. Have fun
01-28-2011, 03:19 PM #6
Band-aids are for punks rub some oil and dirt in there
01-28-2011, 04:02 PM #7
Just replaced my headers a weak ago. I hope you have small hands and patience. I would never do it again. Plus just delete the EGR and AIR system they are useless components. You will need to have a tune done anyway just have them tuned out with the secondary O2 sensors. And if you haven't done a tune up now is the time. By the way if your interested I have an extra 2 1/2" electric cut out I need to sell if your interested. A
01-29-2011, 09:51 AM #8
if you have a lift it makes life a lot easier, took me and my brother about 2.5 to 3 hours to take off manifolds all the way to the tips off, put new plugs in, install the headers and put new wires on. If you have stock plugs and wires, why not upgrade them while you have the extra room?
01-29-2011, 12:55 PM #9
- Dec 2006
- Winter Garden, FL
Good idea, I'll be sure to do that too while I have the chance.
01-29-2011, 02:09 PM #10
Remember Anti-seize and PB Blaster are your friends.
Beer for buddies that help
01-29-2011, 04:14 PM #11
I just did headers a couple weeks ago. Some things I figured out:
- Make sure you have enough lift. You won't need much to get everything off, but you won't be able to fit the headers under the car if you don't have enough. I'd estimate 20" minimum clearance is needed. 24" is better. A lift is ideal.
- Have a good assortment of sockets and extensions
- When you try to raise the headers into place, identify places where it's hitting something and work out a common sense way to alleviate the problem. If you try to force them in there, you'll crack a plug (if they're in) or scratch the headers up or dent them.
- The 02 extensions sold by numerous online retailers work great. They're weatherproof and plug right in. My car hasn't been driven much and the 02s are still perfect or I would have got the Corvette rears, but the extensions are a quality product and much cheaper.
- Remove the EGR first, and also remove the passenger-side coil pack before getting started. Makes things much easier.
- A good torque wrench that gives you positive clicks (not just one barely discernible click) is helpful on the header bolts.
- Oh forgot to add... Advanced Auto had a 1 3/8-1 1/2 freeze plug that will fill the EGR opening in your intake, if you hadn't considered that yet...
This job would have sucked alone. With a buddy it was really no big deal. Time consuming but fun and definitely worth it for the results. If you take your time and are thorough you'll be really happy with the results.Last edited by nmbr5ml; 01-29-2011 at 04:22 PM.
01-30-2011, 07:45 AM #12
01-31-2011, 08:44 AM #13
When I did mine I tried to do everything on the top side first. Then after car was in the air I didn't have to worry about going back in forth as much. Highly recommend having a buddy help you. Its a real bitch to hold headers from the bottom and try to put bolts in. Also be prepare for the drivers side headers to have issues. It seems there are as many issues as there are headers. I got lucky and was able to get mine up there without lifting the engine up. Many will say while down there go ahead and install new motor mounts. More work but worth it if you go with the poly.
01-31-2011, 09:13 AM #14
01-31-2011, 08:18 PM #15
Motor mounts.
Your stock mounts are going to be worn out and while you have everything apart you might as well upgrade the motor mounts to polys. This will help you out tremendously by lessening the possibility of the Y slapping the floor when the motor torques.
I ended up getting new OEM gaskets because when I pulled my manifolds off the stock gaskets fell apart. The gaskets are around $30+ each, but are WAY better than the paper/fiber gaskets that come with most headers.
Lastly, plan for a tune to tune out the EGR/AIR codes. Frost does great work and is fast. I waited until I had done a bit more work (changed rear gear as well) and the car runs dramatically different before and after the tune with headers.2000 Pontiac Firehawk #0041 of 742
02-01-2011, 05:52 AM #16
- Dec 2006
- Winter Garden, FL
Yeah I'm looking for a 9" at the moment as well, once I get all of that complete I plan on getting it tuned by frost. I don't know who else to take it to around here in Orlando that I would trust, I used to be spoiled because Mike Norris was literally 5 min from where I live.
02-01-2011, 08:31 PM #17
- Nov 2010
- The Woodlands,Texas...N.O.
Pewter Metallic- 2000 Pontiac Trans Am WS6
dam i might have to pay someone to put my headers on LoL! i might as well buy new motor mounts,plugs,wires,rear corvette o2 sensors or 02 sensor extensions etc while im at it,i had it good with my first two T/A's they both had headers,y pipe & full exhaust already i thought the third time was a charm? LoL!
02-07-2011, 07:17 AM #18
Thanks for the referral and nice words!
Tuning gives a lot of bang for the buck if done with headers and lid!
http://www.tunedbyfrost.com/products_m03.htm
All my parts are ordered now I can't wait!!!!
By Durango in forum General HelpReplies: 0Last Post: 02-21-2011, 12:33 PM -
Ordered new parts
By t5munoz in forum Camaro / SSReplies: 3Last Post: 02-20-2011, 08:33 PM -
Parts list i just ordered
By 2000ls1tranz in forum Internal EngineReplies: 23Last Post: 05-10-2010, 10:39 PM -
Installing new parts, ordered more :)
By M-Ten in forum Firebird / WS6Replies: 29Last Post: 12-18-2007, 05:39 PM -
PARTS PARTS PARTS...tires, wheels, sway bar, G-Tech, etc.
By BackinBlack02SS in forum Parts For Sale / TradeReplies: 22Last Post: 01-29-2006, 01:36 PM
