Thread: 77 camaro need better ride.
02-01-2020, 02:27 AM #1
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
I have a 77 Camaro that have a 383 in it the car runs great but the ride is ruff. what can I do to improve on the ride, everything under the car is stock but new need help with ruff ride.
02-05-2020, 12:59 PM #2
Did you install the suspension components yourself? Reason for asking is to check if you final tightened the suspension bolts with weight on the wheels instead of at full droop, a common oversight that causes a preload on the rubber bushings in the control arms and leaf springs. Also, what shocks are you running, that's a big factor in ride, moreso than springs. How are the subframe mounts? Did you install new rubber ones or did you go with solids? My 78 Firebird is lowered with Pro Touring F-Body comp suspension system with no name chinese adjustable shocks (supplied with the kit 5 years ago), subframe connectors and solid body mounts. The ride isn't bad, only the harshest of bumps make me wince, and it's pretty tight feeling the rest of the time.
08-14-2020, 12:53 AM #3
- Mar 2015
- Fl
Replacing or upgrading the suspension components can improve the ride quality.
09-23-2020, 06:26 AM #4
- Dec 2019
- Phoenix, Arizona, USA
A new set of tires and shock absorbers can do wonders in improving your car's ride quality.
need a better ride for my 77 camaro.
By Street Fighter in forum Classic MuscleReplies: 5Last Post: 05-26-2019, 11:23 AM -
1995 camaro ride height
By 1MileCrash in forum LT1Replies: 4Last Post: 05-08-2017, 07:04 PM -
Huge Camaro Ride Out In California
By MaroBoyzPrez in forum Western MembersReplies: 1Last Post: 05-09-2012, 11:09 AM -
1969 Chevy Camaro SS - Joy Ride
By Ed Blown Vert in forum Camaro / SSReplies: 1Last Post: 08-04-2009, 02:17 PM -
Selling the Ride 1998 Camaro V6
By Promise517 in forum Vehicles For Sale / TradeReplies: 1Last Post: 06-15-2007, 12:06 AM
