Results 1 to 13 of 13
Thread: patriot ls6 and a 224
08-06-2007, 12:00 PM #1
- Jul 2007
- Madison, WI
Black- 2000 Pontiac Trans Am WS6
I have been readding that this is the best set-up for a DD car. I was wondering where the best place the get them. Thanks
P.S. I wont be putting these on till later this is more for a wish list. Alsowould a LS^ Intake be good orshould I just go for the ported FAST 90/90 on there know since I plan to do the head cam?
08-06-2007, 04:45 PM #2
Personally I'd go with PRC LS6 heads from Texas Speed. Should be about the same price, better results from what I've seen tho.
08-06-2007, 08:34 PM #3
maybe try speed inc?
08-07-2007, 11:13 AM #4
- Jul 2007
- Madison, WI
Also with the FAST 90 can I put a stock TB on it or do I have to put a 90MM on it right away? I will put a nick williams on it eventully when I do head cam just wondering If I could use a stocker.
08-08-2007, 01:03 PM #5
08-08-2007, 01:22 PM #6
- Jul 2007
- Madison, WI
does porting do the 2xx some they charge for it or just get the unported?
08-08-2007, 02:02 PM #7
08-08-2007, 02:49 PM #8
If you're doing H/C why not go for the intake too? Why not do the LS6? They are capable of supporting up to 500 hp. I got my 224/224 with 112 LSA from thunder racing. Good guys.
1998 Camaro Z28 1LE: TR Cam (plus normal cam install upgrades), Ceramic coated Pacesetter Headers, ORY, SLP Loudmouth (SOOOO Loud), B&M shifter, Lid, All free mods, Tubular Panhard, LS7 Clutch
1978 Firebird: Chevy 350, 4 bolt to many mods to list
08-08-2007, 02:56 PM #9
i suggested that because i have a H/C car and back in Janurary I installed an Ls6 intake with the heads, and gained 36/24 respectively to these number (409/386 with my 224 .581 112lsa). this past friday, i installed a ported FAST 90/90 combo and gained an additional 35rwhp/10rwtq (now sitting at 444/395) over the Ls6 intake. why waste the money on an Ls6 intake...?
just get the FAST 90/90 and be done w/it the first time out...
click on the link in my sig and you will have a video write up of my car. here is my write up in regards to the FAST 90/90...
http://www.ls1.com/forums/showthread.php?t=589412018 CTS-V: °°668rwhp/658rwtq°°
2013 ZL1: °°590rwhp/576rwtq°°
08-09-2007, 05:40 AM #10
- Jul 2007
- Madison, WI
sorry I think I had my mind on something else when I wrote that. what I ment was is porting worth it?
and not really for this thread but how do you get the bottom bolt of the EGR hooked up to the header? do you have to go from the bottom?
08-09-2007, 06:12 AM #11
i do not know about the EGR bolt, i removed both my AIR and EGR and then cut off the provisions from the headers and had them welded over and grinded down...
08-09-2007, 06:20 AM #12
- Jul 2007
- Madison, WI
ok thanks um do you have any instight into porting?
08-09-2007, 07:25 AM #13
personally, no. i leave that to the professionals...
AFR or PATRIOT
By fahadss in forum Internal EngineReplies: 29Last Post: 10-27-2008, 08:49 AM -
patriot heads
By ghui99ss in forum Internal EngineReplies: 5Last Post: 07-29-2007, 04:33 AM -
Patriot cam 226/226
By 98-LS1 in forum Internal EngineReplies: 11Last Post: 11-15-2006, 05:01 AM -
Need help with Patriot Cam
By fordkiller in forum Internal EngineReplies: 5Last Post: 07-08-2006, 11:35 AM -
The Patriot Act. It's like, about terror, ya know?
By jking in forum Political / Debate ForumReplies: 3Last Post: 03-07-2006, 02:56 PM
