Thread: Job time estimation?
09-19-2009, 06:48 AM #1
How long would you estimate a garage would take/charge to replace the header bolts on my 96 lt1 with the rediculous slp headers? i attempted it, and found that only 1 of 12 bolts is actually really serviceable. It looks like the bolts have to be slid in on an angle to clear the headers, then the entire headers moved into place to screw them in. At least some of them. I cant even see the passenger side, but I'm assuming they are the same if not worse.
How long does it take to drop an lt1 out of a car? ie what would I be looking at price wise? I figure if thats whats gotta be done it might be cost beneficial to do a front timing gasket and rear main seal since both are slowly leaking, and I have been just ignoring it because its cheaper to but an extra quart of oil between changes then have it done! but now i might have a needy excuse to have the motor dropped?
09-19-2009, 12:14 PM #2
Any shop worth half a shit shouldnt have to drop the motor to do the header bolts. I've never worked with SLP headers but I cant really see how it could be much worse than any other header. The bolt holes and the primaries are always going to be about the same distance from each other.
09-21-2009, 02:27 PM #3
- Feb 2006
- Orange County, NY
Have you tried loosening all of them up and removing and reinstalling them one at a time?
09-22-2009, 04:11 AM #4
No, simply because if I can't get em back on, then I'm fucked. This is gunna have to be a garage thing, I just need to know how much I need to save up.
09-22-2009, 04:22 AM #5
I can't recall all the differences on lt1/ls1, but I would imagine since you already have LT's, to get all the bolts you would need to remove coil packs, emissions if applicable, plug wires, and oil pickup tube. You should be able to hit all from top or underneath afterwards.
Are they being removed completely for a gasket change, header swap or just replacing the bolts?
09-22-2009, 04:54 AM #6
No Coil packs in the way. Coils are mounted up front on timing chain cover.
On my '95 I have LT's and can change all drivers side bolts from the bottom. Passenger side was a bit tougher front bolts got to from the bottom and back ones from the top. I think I used a swivel on 1 pass side bolt.
09-22-2009, 05:53 AM #7
- Jun 2008
- Annapolis, MD
BLK/BLK w/CGM Stripes- 2010 Camaro 2SS/M6
SLP headers are a pain in the ass to install and access plugs after the install. Crappy design.
Power Estimation
By lingenfelter69 in forum Internal EngineReplies: 41Last Post: 06-03-2010, 05:52 PM -
first time posting, long time reading
By bamaballa205 in forum New Member IntroductionsReplies: 3Last Post: 06-01-2008, 12:45 PM -
Long time guest first time member
By strebej in forum New Member IntroductionsReplies: 2Last Post: 08-08-2007, 07:19 PM -
HOLY CRAP! It's that time again! It's time for another Nitrox28 nekkid chick thread!!
By nitrox28 in forum Almost Anything GoesReplies: 55Last Post: 11-16-2006, 08:39 PM -
1/4 mile estimation
By PEWTER Z in forum Drag RacingReplies: 4Last Post: 04-08-2006, 02:22 AM
