Results 1 to 16 of 16
Thread: Vibration in 3rd gear only
09-05-2013, 11:50 AM #1
- Jul 2013
- Jacksonville FL
Pewter Gold- 2000 Camaro Z28
Hello All,
Im in need of help, I have 2000 camaro ls1 460LE tranny, and in drive soon as it hits 2000 rpms, it starts vibrating bad. 1st and 2nd gear is fine, overdrive is fine, My mechanic and I are baffled now, heres a list of what we have done
Replaced 1 tranny mount, one had a lot of play in it but the others looked good
Tranny shop hooked it up to computer and didnt get any miss shifts or slipping
replaced both joints on driveshaft
serviced the rear end.
balanced the rear tires
We are testing the drive shaft now to make sure there isnt any warping but its all stock so I cant imagine the shaft being warped.
If anyone has any other ideas let me know.
Thanks
09-05-2013, 11:51 AM #2
- Jul 2013
- Jacksonville FL
Forgot car idles and shifts fine to. Only in 3rd gear once u get to 2100 rpms
09-05-2013, 12:04 PM #3
Ya'll have covered pretty much everything already. It may be inside the tranny itself.
09-05-2013, 03:15 PM #4
Sounds exactly like the typical 3rd gear clutch shudder. I've had quite a few 4L60's that did that.
No real cure for it other than tuning the trans tables or rebuild.
Just a heads up, I've played with trans tables and line pressures in the tune and was able to tame it down but never able to completely get rid of it. So I drove the car for years and figured I'd rebuild when it let go, but it never did. Fluid always looked nice and the pan was free of sludge during routine service intervals
Even a rebuilt 4L60 I had that was built to handle abuse, coleen steels and red alto clutches, 5 pinion planet, beast shell , shift kit, etc etc....also had a very very slight 3rd gear shudder but wasn't there all the time, only light throttle situations.
So I personally wouldn't worry about it unless it's jarring your fillings out or making the CD skip Then I might want to address it.
09-06-2013, 03:45 AM #5
FBJ - would you recommend a transmission fluid and filter change? I run semi-synthetic Dex VI in ours, and fortunately had no issues with the stock transmission prior to it being swapped out. Back in the day, we'd dump Type F in the GM's for a bit more bite... but that's probably not a great idea on our cars.
09-06-2013, 04:50 AM #6
A fluid and filter change is a good idea. Give you a chance to see if anything has settled in the bottom of the pan. My experience with autos, if the fluid changes aren't done that often, that it's normal to see some sediment in the bottom of the pan. Doesn't necessarily mean there is a problem with the trans, I see it a lot on transmissions that haven't been serviced routinely and they work fine for years afterwards.
I tend to change mine about every 10-12,000 miles and as long as I stay on that schedule, the bottom of the pan stays pretty darn clean.
On the Type F, I do it hear on the old GM stuff (350 and 400 turbos). A lot of people (and racers) would spend a lot of money on the B&M trick shift when the Type F did the exact same thing for half the cost. It provided crisper shifting.
I agree though, not something I want to try with the newer overdrive stuff like the 4L60. I just stick to the regular Dexron.
09-13-2013, 02:06 PM #7
- Jul 2013
- Jacksonville FL
Ok to close out the thread we found out it was the motor mounts, the GM motor mounts have a plate in them that keep them from collapsing to the bottom, so visual inspection they looked good but when we actually inspected them by lifting up the motor with a prybar the motor moved a lot, took them out to find one completely dry and cracked rubber to one almost all the way collapsed had it not been for that plate it would have collapsed. Thanks for all your help though guys.
09-15-2013, 05:06 PM #8
Good find. Upgrading to poly mounts?
09-18-2013, 03:43 AM #9
- Jul 2013
- Jacksonville FL
09-18-2013, 05:00 PM #10
Poly motor mounts are not an issue -- I run them in our car. It is the poly trans mount that generally causes issues. I installed one and ended up yanking it after just a couple of days due to the vibration.
09-20-2013, 04:01 PM #11
09-20-2013, 07:50 PM #12
Poly tranny mount here...No problems with shaking? Maybe im used to my car..What and when was the shaking/ vibrations you guys felt? Just curious?
09-20-2013, 07:57 PM #13
09-20-2013, 08:01 PM #14
AHH HA- i was just coming back to say ive got a MT..but its in my profile anyway- Your probably right!
09-20-2013, 08:13 PM #15
09-21-2013, 04:11 AM #16
I had awful vibration with the poly mount. It has been suggested that it changes the driveshaft angle as it is taller, but even idling the thing vibrated terrible.
vibration
By shadowsnkx in forum DrivetrainReplies: 4Last Post: 07-31-2008, 06:14 PM -
2002 Camaro ss a4 Help! redlines a gear then changes a gear from a roll please read!
By hmorris7000 in forum Camaro / SSReplies: 24Last Post: 06-05-2007, 03:01 PM -
By hmorris7000 in forum General HelpReplies: 9Last Post: 06-01-2007, 05:18 PM -
vibration
By JROBINSON1016 in forum Internal EngineReplies: 5Last Post: 03-20-2007, 05:23 PM -
vibration in 3rd gear
By lt1dragon in forum Manual TransmissionReplies: 13Last Post: 08-09-2006, 09:42 AM
