Results 81 to 100 of 141
Thread: LS6 valley cover in pics
01-06-2011, 05:40 PM #81
- THE SWAMP
Great pics to go with a great job. As with any kind of modification, the more pictures the better. Thanks all.
01-09-2011, 06:46 AM #82
- Jan 2010
- texas
silver- 2000 formula
the PN for the OPSU is 12562267.......paid 77$ at the dealer......waaaay cheaper at rock auto
01-10-2011, 05:58 PM #83
i made mine.. i like most of us broke my opsu off... so i took a older on that had a full metal body and made a 3/8s pipe to the stock hole in the block... 15x1.5 i think dont hold me to that but i havent had any issues and if i do break it back off its only afew bucks to get one off an older gm...
btw a 3 wire and a one wire have that one wire that works for the same the other 2 just trun on a oil light if thats all the car have stock..
02-01-2011, 05:24 PM #84
- Apr 2008
- Madison, WI
Added to the Gen Help Tech Stickies!!...should have done this along time ago
02-01-2011, 08:51 PM #85
- Jan 2010
- texas
that will teach ls1howto a thing or 2
02-01-2011, 08:53 PM #86
- Jan 2010
- texas
02-02-2011, 01:33 PM #87
- Feb 2011
- AZ
black- 2000 Camaro SS
BTW you can re-use the ls1 coolant pipes if you're keeping the ls1 intake. You just have to do some minor bending on the the front, to bypass the pipe out of the ls6 valley cover.
Another tip: it's easy to crush/break the wire from the #2 knock sensor when you re-install the intake. (Ask me how I know), due to the bump on the ls6 cover that's not there on the ls1 cover. You'll then get a knock sensor low voltage code, and have to take it apart all over again. So you'll need to be careful about wire routing.
And yet another tip: don't glue the knock sensor covers onto the vc with sealant like I did, it's about impossible to get them out again.
The holes in the new style vc are supposed to replace the pcv valve, but if you have the old style ls6 cover you can just keep your external valve in the hose loop (I sort of prefer that option).
02-05-2011, 10:09 PM #88
- Jan 2010
- texas
i switched to the LS6 coolant tubes for a future fast intake......i think my KS wiring harness was already screwed up when i took it off......got a new one for my soon to be LS6 intake install
02-06-2011, 03:09 AM #89
02-08-2011, 07:16 PM #90
- Jan 2010
- texas
the front KS wire was pinched when i took off my manifold.....that hump on the intake did it......no hump on the LS6 intake
02-11-2011, 11:58 AM #91
One more thing to add to this thread that I learned.
Knock Sensor Wire Harness (KSWH) - you need to be careful on its placement. When I did the LS6 Intake install some how my KSWH was moved durning the seating and it got pinched causing the KSWH to fail. As you can see in the picture below this is not where it should be seating. After replacing the harness I used some high temp tape to hold it in place.
FINISH PRODUCT
02-11-2011, 07:32 PM #92
- Jan 2010
- texas
cute catch can
02-12-2011, 10:38 AM #93
yeah it's shiny
02-12-2011, 04:53 PM #94
- Retired Outlaw Sum Bitch
Sticky Worthy
02-12-2011, 07:26 PM #95
- Jan 2010
- texas
i likez stickeez
02-16-2011, 11:26 AM #96
Ok so if im doing an LS6 intake manifold on my 98 shoud I switch to a LS6 valley cover while im at it? Is it really needed? already go the LS6 steam tubes and rear block offs on the way, As well as EGR/AIR block offs. Got a catch can but not installed yet.
02-16-2011, 03:18 PM #97
- Jan 2010
- texas
it will save you the hassle of messin with the stock PCV crap in the future
02-16-2011, 05:10 PM #98
- Feb 2011
- AZ
If you don't mind dremeling the block it's worth it.
Something I found though - I think the holes for the knock sensors might be slightly bigger in the ls6 vc. When I took the rubber covers out of my ls1 vc they were a tight fit, when I put them in the ls6 vc they were loose. I got a new knock sensor harness, which had some differences from my old one (from 2000), and the covers fit tightly in the ls6 vc. I threw away the ls1 vc too soon so I couldn't compare them directly.
02-16-2011, 08:14 PM #99
- Jan 2006
- Shepherd, Michigan
i think it might just be the older rubber ..as soon as you take them out..they dont expand a little like newer ones would
02-18-2011, 12:05 PM #100
- Jan 2010
- texas
my new rubber was nice n tite............the old rubber was almost dry rotted
LS2 Valley Cover
By PitchBlackLS2 in forum LS2/LS3/LS4/LSxReplies: 0Last Post: 11-28-2016, 06:49 AM -
Question: ls6 valley cover
By tangkiller_z28 in forum General HelpReplies: 7Last Post: 07-13-2011, 12:05 PM -
Valley cover
By sutie in forum Firebird / WS6Replies: 5Last Post: 02-24-2011, 05:07 AM -
LS6 Valley Cover and Catch Can
By ls1camino in forum External EngineReplies: 11Last Post: 05-20-2009, 08:23 AM -
LS! Valley Cover
By parbreak in forum Parts For Sale / TradeReplies: 0Last Post: 04-22-2006, 06:26 PM
