Results 41 to 42 of 42
Thread: Trans am won't start
05-27-2007, 09:22 PM #41
looks like it's time to break out the ole instruction manual for a snap on mt2500 tonight and go sit on the crapper and do some reading. I know that's where I do my best reading. Getting good at logging data will save you tons of headaches down the road. I would start out with map, O2 voltages, timing,maf, and fuel trims at a minimum. There are several other things you'll want to look at first but solving this map issue is probably job 1 at the moment.
06-02-2007, 08:12 AM #42
- May 2007
- Southeast
black- 1998 trans am
Just an update for anyone following this thread.
I took the car to a local tuner and they changed out the final three plugs, put a gallon of c16, and another 5 gallons of fresh gas in the car. They also swapped out the MAF, MAP, and CPS which fixed all of the SES codes it was throwing.
The car will now idle sort of normally (approx 900-1000 rpm) and jumps to 1600 or so every once in a while but still does not run right. It is also coughing through the intake every once in a while. When shifted in to gear the engine dies. They are going to do a compression test and go from there.
Trans am start up
By WS SIX in forum Firebird / WS6Replies: 3Last Post: 01-30-2013, 06:17 PM -
Trans am Start up?
By WS6 MANN in forum Firebird / WS6Replies: 1Last Post: 01-06-2013, 11:11 AM -
1997 Trans AM Will not start please help.
By mystictealZ28 in forum LT1Replies: 6Last Post: 03-29-2010, 09:14 PM -
trans am.. where to start
By mr_r0bert0 in forum Classic MuscleReplies: 39Last Post: 10-04-2009, 02:13 PM -
New Trans Am, now where to start?
By TransAmlover90 in forum Firebird / WS6Replies: 44Last Post: 02-10-2008, 07:54 PM
