Results 21 to 40 of 53
  1. #21
    USA
    BLACK
    Z/28 LS1
    The main thing that causes swirls is grit/dirt that is dragged around during washing the car and the use of inferrior products/quality towels, improper washing technique.
    -Use the two bucket system when washing a car and use a grit gaurd on the bottom of each bucket
    -Use a quality car wash that has essential oils that lubricate the paint to remove dirt/grit
    -Use a microfiber wash mitt or something of equal quality
    -Use only quality microfiber clothes to dry the car-not water blades or absorbers that do not have pores that remove grit from the surface instead of dragging grit on the surface
    -Using these things with help prevent swirls but polishing is still required occasionally then use a quality wax or sealant
    -learn the difference between waxing and polishing
  2. #22
    Senior Member SS02's Avatar
    None
    My buddy many yrs ago... said 100% USA Cotton!
    I live by it. It really does work.... He paints cars!
  3. #23
    None
    He was and is a very smart man.
  4. #24
    SATX
    2000 Trans Am
    I snagged a pack of cloth diapers from my sister and they do wonders for my car. not only are they supper soft (ideal for removing wax) but they absorb well too. just my .02
  5. #25
    Junior Member DS-LS1's Avatar
    Richmond, VA
    White 1999 WS-6
    Black 2000 WS-6
    Has any one ever use rubbing compound?
    I have heard that a good rubbing compound will take out swirl marks, if done correctly..... If done incorrectly, it can cause more marks.
    Ive never used it so I dont know.
  6. #26
    NeW YoRk
    2001 ws6
    Quote Originally Posted by DS-LS1 View Post
    rubbing compound is amazing stuff if used properly, i recomend 3M rubbing compound, amazing stuff
  7. #27
    USA
    BLACK
    Z/28 LS1
    I would use a polish for swirls rather than a compound because compound it reserved for major swirls,oxidation, and scratches. No need to remove more clear coat then necessary. Just my opinion.
  8. #28
    NeW YoRk
    2001 ws6
    if ur compounding a car for the first time you should be alright, but yes, compound cuts a layer of the clear, swirl marks arent in the paint there in the clear, the deeper the swirl the more clear is needed to be removed but MOST swirls will be taken care of by removing "one layer" of clear
  9. #29
    Member iam_dale's Avatar
    Bann, Germany
    02 WS6
    Quote Originally Posted by LETHALxLS1 View Post
    A very good point. I used to detail cars years ago, so I used alot of compound. It does work, but you have to know what you're doing, or you can fuck your paint up worse. I actually used it different than most. I DID NOT use a high speed buffer. I had a huge "industrial" sized orbital buffer. The damn thing weighed about 25 pounds. It takes longer to do it that way, and I had to use more pressure, but it removes the chances of turning an edge on the paint and leaving a burn mark.
    dale
  10. #30
    Pa
    Blue
    2000 TA
    Soft paint, abrasive dirt and any light source that reveals imperfections.
  11. #31
    USA
    BLACK
    Z/28 LS1
    On most swirl marks you simply dull the sharp edges of the swirl therefore making it "invisible"- but they are still there.
  12. #32
    Auto Painter RyanJM's Avatar
    Houston, TX
    speaking of hard water....has anyone had any luck with those filters that fit on the end of the garden hose? I have well water and although it's not bad well water it'll still leave spots if the sun hits it before I get it dried. I normally have to wash it in the drive and then pull it into the garage to dry it. Pain in the ass. I've just never heard anyone say good things about those filters.
    I had one of these when I lived in FL. Pricey but worked great.
    http://www.griotsgarage.com/p2p/sear...rrivals&page=1
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
  13. #33
    Awaiting Activation superman4evr's Avatar
    Grandville, MI
    Red Jewell Tintcoat
    2008 Grand Prix GXP
    I've commented on other forums about this. Since my car took the serious beatdown this winter(Not an LS1), I made it a priority to examine my options and this is what I did.
    After washing the car with a 2 bucket system. I clay barred it.
    After it was all dry,
    1. I used 3M Rubbing Compound on the enitre car.
    -After that I got every swirl and fine scratch out!
    2. CarBrite Black Pearl #4 fine polish.
    3. 2 coats of Meguiar's NXT 2.0 Tech liquid wax.
    4. 1 coat of Collinite #845.
    Of course you can sub out the Black Pearl for another polish. Rubbing
    compound should be followed by that or a 3M machine polish or something
    good.
    I couldn't be happier with my results.
  14. #34
    USA
    BLACK
    Z/28 LS1
    Quote Originally Posted by superman4evr View Post
    good.
    PICS!!!! Sounds like a job well done!
  15. #35
    Think Spring..... 4get gto's Avatar
    Northampton County, Pa.
    2000 WS6
    I don't think this is his first parade....He did it good.........
    2000 NBM WS6
    /oo_________oo\
    |==_/_ws6_\_==|
    ><(((º>´¯`·.¸¸.·´¯`·.¸¸><((((º>
  16. #36
    2000 WS6
    Quote Originally Posted by 4get gto View Post
    superman4evr......
    hope you know I mean this in a good way.....
  17. #37
    Grandville, MI
    Red Jewell Tintcoat
    2008 Grand Prix GXP
    superman4evr......
    Not at all. We are good!
  18. #38
    Omaha, NE
    2000 Z28 Camaro
    what do most of you use for a wash mit? i was gonna get a sheep skin wool one at target
    i'll probably use a good chamois for drying, what do most of you use to dry?
  19. #39
    Grandville, MI
    Red Jewell Tintcoat
    2008 Grand Prix GXP
    Quote Originally Posted by allbaugh_04 View Post
    A MF or sheepskin would be excellent. I would buy a grit guard for the bottom of your bucket. That will keep the dirt out of your reach. Otherwise
    you can use a 2 bucket system. I use a California water blade to get all excess water off. I dry with a MF towel.
  20. #40
    Omaha, NE
    2000 Z28 Camaro
    sounds good, i'll find something else to wash the lower part of the car and dry it, thats where most of the dirt and grime get
  1. Removing Swirl
    By FMBL in forum Showcar and Detailing
    Last Post: 02-23-2012, 06:06 AM
  2. Help: swirl marks
    By Pony_Eater in forum Showcar and Detailing
    Last Post: 12-10-2008, 07:06 PM
  3. Swirl Removal?
    By BlueMagicSS in forum Showcar and Detailing
    Last Post: 08-29-2008, 11:15 AM
  4. swirl marks?
    By CamaroKurt in forum Showcar and Detailing
    Last Post: 10-26-2007, 06:29 PM
  5. How do I remove swirl marks ?
    By Speedy_Gonzales in forum Showcar and Detailing
    Last Post: 03-27-2007, 07:06 PM
