Results 21 to 27 of 27
10-05-2006, 11:31 AM #21
yea gotta start somewhere,might as well do it yourself.if you cant pull this off ,your bent over for the dealer to have his way with you everytime you need something.maybe if your lucky he'll want to go steady,lol ,thats funny,i dont care who you are,lol!
10-06-2006, 08:29 AM #22
I agree with what most people are saying. Buy a haynes manual and tear into it. It'll be a good learning experience and save you a ton of cash. I'm sure you won't breeze through it like most people are saying if it's your first time but it can be done and if you have a little bit of mechanical aptitude and are able to read it's definitely a job you can do. At the very least you'll invent a few new cuss words.
10-06-2006, 10:23 PM #23
ahahha...they saw you coming a mile away..did they tell you it was a hard job as they swiped your card for $1000
You've been a member here long enough to know better bro...there's tons of people here with a lot of knowledge that would've helped you through every step if needed. Just a shame that you had to waste a good 700 bucks.
As far as the gasket comment it's possible it's just the gasket...but i'd replace the pump anyway if it has any decent mileage as preventive maintenance.
10-08-2006, 09:02 AM #24
What a coincidence, I replaced my water pump last night! lol One thing that took a long time was getting the clamps off the coolant lines, and back on. You might want to get something better than pliers... lol Although my rubber lines have swelled a little bit, so it probably won't be that bad...
10-08-2006, 09:33 AM #25
Those stock clamps are crap...anytime you get a chance you should replace them with some worm clamps
10-08-2006, 01:21 PM #26
Yea after reading this I made the mistake of having a mechanic replace it, but he gave me a good deal nevertheless.
$609 for new water pump, thermostat, fan belts (replace them because you're taking them off anyways), flushed dex-crap, cleaned lines with an agent, re-filled with traditional green, and labor. Not bad huh? Find someone else. This maybe because the guy just replaced my transmission with a $2700 Jasper 4L60E and replaced my cylinder ignition key.
BTW, if you flush the system, get rid of Dex-Cool. When my water pump was failing sporadically, I saw that my coolant was beginning to change colors as air mixed with the coolant. It got this white sludge all over my overfill tank, which may have been acid. My suggestion is to stay away from Dex-Cool because it does turn into acid mixed with air & heat. GM has had suspicious problems with head-gaskets failing after switching over to Dex-Cool. BTW, aluminum easily corrodes when acid is present. http://www.dexcoolcase.com
10-08-2006, 02:43 PM #27
Help: Scammed by dealer on 2004 gto Blown engine oil pressure
By slinky in forum GTOReplies: 9Last Post: 09-17-2011, 06:13 PM -
I put a water pump on now.......
By Cohi in forum General HelpReplies: 5Last Post: 03-17-2009, 08:42 AM -
water pump
By blackout5.3 in forum External EngineReplies: 1Last Post: 02-04-2008, 05:27 PM -
Do electric water pumps pump enough water for daily use?
By xinthenight in forum External EngineReplies: 6Last Post: 08-02-2007, 09:04 PM -
Water Pump Help.
By gisselle19 in forum General HelpReplies: 21Last Post: 02-01-2006, 06:06 PM
