Results 21 to 40 of 43
Thread: Moisture inside back-up light.
06-27-2009, 02:05 AM #21
- Oct 2007
- Beaver Dam KY
The tailight is ruined forever. I VHTd mine, the chrome is gone off the inside. New tailights will get it bright in the daylight again.
and if you guys dont believe me, take the lense off the housing
06-27-2009, 04:03 AM #22
I put my cover in water to see where the leak is. I looked for bubbles. I took it out and let it dry for aleast 24hrs. Then put a bead of black silicone around it. I put it back together. Then I used black electrical tape around the plug in sockets. so for so good. I have been in the rain and washed the car with no problems. You might try that.
06-27-2009, 04:34 AM #23
I had this problem which started shortly after I bought the car. I seemed to be drying out the moisture everytime I washed the car. I ended up drilling three small holes in the assembly as a test to see.
Make sure you find the lowest spot by holding your light level. That will verify all water drains out and should keep any moisture from building up.
Took a shop vac with a small hose attachment and stick it in one of the holes. three pieces of cardboard over the others and after about 3-4 min all the moisture and water was long gone.
I know it's probably not the most popular solution, but I was looking at the price of the housings on ebay that were pulled from junkers and they could have the same issue.
06-27-2009, 06:07 AM #24
- Feb 2008
- iowa
red- 98 trans am
They make a thicker gasket that goes between the bulb and housing. Solved my problem. I think they were $10.00 for a pair.
08-12-2009, 01:12 PM #25
- Jul 2005
- Central TX
Sunset Orange Metallic- 2002 WS6
Well I have been through 2 sets of tailights and I got a new pair but damn it...this is the last. So, what most are saying is that you can replace the lights with LED's and this will prevent the burnout? But what will prevent the actual moisture from getting in? I hear drill, I hear silicone? What's the best?
Same thing for my front turn signal........
08-14-2009, 07:00 PM #26
front drls are a heat issue, which LED's could help if you fix the housing. the backs not so much. I just drilled 3-4 small holes in the bottom of my leaky tail light and ran a bead of silicone around them and no problems since.
08-23-2009, 08:10 AM #27
09-17-2009, 04:54 AM #28
- Aug 2009
- Maryville,TN
Black- 99 Trans Am WS6
You can use dielectric grease on the rubber surrounds of the lamp plastic sockets. I used clear free flowing silicone that was made for windshields. I purchased it from Autozone. It comes out a little more fluid and gets into the crevices.
09-21-2009, 01:12 PM #29
- Feb 2008
- iowa
red- 98 trans am
I got them of the internet. Can't remember were? Just do an internet search.
09-21-2009, 02:11 PM #30
- Jul 2009
- North of the Motorcity
Found a better fix, should have took pics. There was a hole covered by a circular sticker, looked OEM, pulled it off and a few days later the moisture was gone and has stayed clear since. When my LEDs come in and I take the light off again, I'll try to remember to snap a few pics.
09-24-2009, 04:05 AM #31
I pulled the taillight out out and drilled a small hole on the underside of the reverse housing and two small holes on the underside of the taillight housings. No more moisture accumulation.
09-25-2009, 05:05 AM #32
- Jul 2009
All 3 "chambers" in the tail light of my car are all connected. Making them 1 chamber.
09-26-2009, 10:44 AM #33
- Aug 2009
- Florida
White/ Blue stripes- 1999 30th anniversary
I eliminated mine ....by painting it white
problem solved
09-26-2009, 01:10 PM #34
- Jul 2009
LOL.
Since I have that hole in the top of it, i get some moisture build up when i wash it, but the bulbs heat up and evap. the water alittle while later. I get no regular moisture build up anymore.
Maybe, if I ever have 400 bucks I dont know what to do with, I'll buy a new one.
09-26-2009, 04:19 PM #35
- May 2009
- college station, tx
sold: 1999 firebird- 1998 Trans Am
drilled two holes in the back up, 5 in the taillight, no problems yet
10-25-2010, 06:27 AM #36
So, what was the end result of your deal ?? Did you get the LED's ? If so,, where did you get them from? I have an '02 TA and have the same typical problems: moisture in the back-up lens and dim lights all on the left side. And now to complicate matters, I have one of those sub-woofers that fit snugly into that space behind the left tail light area and now I have to rip that out to get to it all I noticed that threads on this are all from last year,, did any one come up with a really good fix since then???
10-25-2010, 07:26 AM #37
05-04-2011, 08:38 AM #38
05-04-2011, 09:07 AM #39
05-04-2011, 09:40 AM #40
Performabuilt holiday giveaway is back see inside
By performabuilt in forum Automatic TransmissionReplies: 8Last Post: 12-21-2013, 06:44 PM -
PerformaBuilt Back to School sale see inside
By performabuilt in forum Automatic TransmissionReplies: 3Last Post: 08-02-2012, 05:23 PM -
Fog Light Moisture Problems
By stockwellsm in forum Stereo and ElectronicsReplies: 0Last Post: 05-16-2008, 09:45 PM -
Moisture on oil cap
By BadA$$ in forum Internal EngineReplies: 4Last Post: 12-04-2007, 08:48 AM -
broken fog light...pics inside
By BLKbandit98 in forum Firebird / WS6Replies: 4Last Post: 11-16-2007, 02:41 PM
