Results 1 to 20 of 45
Thread: Max Jax Lift
10-20-2009, 07:35 PM #1
Max Jax Lift
I had some guys asking about my lift in the Firebird section, so I'm going to post some pics and info here. This is how it looks un packed from the skid:
The towers are held in place by 5 anchors each. When you are done using the lift, remove these anchors and wheel the towers to a corner for storage.
The direction show one of the left ports being used here...it's actually the one on the right...
And it even works! Total build and install took about 4 hours.
10-20-2009, 08:00 PM #2
That is very nice. What was the total cost?
10-20-2009, 08:34 PM #3
Never mind, I found it
I would love this, or any lift. My car is currently on jack stands, again. I am slowly hating jacking the car up and adjusting 4-6 jackstands that it makes me not work on the car. I bet its been on jack stands 20 times this summer. I'm envious of all lift owners.
10-21-2009, 04:46 AM #4
Yeah, I went all out this past summer. After changing a rear main seal in my, while laying on the driveway, I finally said, "That's it!" I got a home equity loan, built a garage, and ordered the lift. The lift was actually $1999 with free shipping, but Conway Frieght charges $130 for lift gate delivery.
10-21-2009, 09:31 AM #5
10-21-2009, 11:07 AM #6
10-21-2009, 05:49 PM #7
Is it an American Made kift?
Total lifting capacity?
What is the max lift height?
10-21-2009, 05:53 PM #8
Nice! What epoxy floor covering did you go with? I would really like to do my floor but am worried about its longevity as it is a working garage.
10-21-2009, 06:03 PM #9
Not sure if it's made in America or not. It was the only one of it's kind available to suit my needs, so unfortunately I couldn't be picky. It's made by Danmar, and people on here have said some of there manufacturing has gone over seas. Lifting capacity is 6000 lbs, and I have had my 5500lb Grand Cherokee on it with no issues or struggles. Lifting height is about 4 1/2 feet.
http://www.maxjaxusa.com/
The floor coating is by UCoatit. I love it. I opted for the clear top coat. very easy to keep clean, but the clear will scuff a bit. Luckily, once you follow the whole process, re-coating to repair damage is just scuff and roll.
http://ucoatit.com/pgs/main.htm
10-21-2009, 06:14 PM #10
10-21-2009, 06:19 PM #11
Abuse: Check
Spills: Lots
Rough treatment: See above
I just finished dropping the whole drivetrain from Firebird, so I spilled everything on it. Oil, brake fluid, antifreeze, compressor oil. It all wiped right up. The only thing that stained it, was a harsh epoxy that has an acid base, Real nasty stuff! As for the scuffing, you can grind dirt into fairly easy, but that's only because of the clear. Bottom line:
Lots of spills- go with the clear top coat
Dragging and scuffing: leave it just color coat
10-21-2009, 06:22 PM #12
10-21-2009, 06:28 PM #13
Definately go for it. Once you stain the concrete, it makes it hard for any coating to stick. The cleaner, the better. These kits come with EVERYTHING you need, except the acid etcher that you can buy at Grainger or a pool supply store. It even gives you gloves and a drop cloth that doubles as a bag to throw everything out!
I will say though, my dad used the Home Cheapo brand and his garage looks pretty good. Cost him about 25% less but he has no clear coat.
10-22-2009, 03:59 PM #14Junior Member
- Feb 2007
- Eastern Long Island, NY
Black 2002 Formula M6- SOLD on 11/21/2009
Great info and photos. Thanks for sharing it with us!
10-22-2009, 04:00 PM #15
No problem. Glad to help!
10-22-2009, 09:06 PM #16
good thread.....how hard is it to install and remove the anchors? Just 5 bolts each side and your done?
10-23-2009, 01:29 PM #17
Yup, that's it. And I shouldn't have said anchors. They stay in the concrete, and sit flush so thay don't snag. You remove the 5 bolts, tilt it back on it's wheels, and roll it away. The two fluid lines are quick release, and zero drip.
10-23-2009, 02:11 PM #18Senior Member
- Mar 2007
- Henryetta/Tulsa Oklahoma
I very much like this setup. My dad has a nice two-post in his garage, 8,000lb limit and will lift the car above my head. But it's currently down with some hydraulic issues...
I'd like to get one of these when I get around to getting a garage and/or buying a house that already has a garage. This would be perfect for me.
10-25-2009, 05:45 AM #19Member
- Sep 2008
- Atlanta, GA,Ft.Walton Bch,FL
- Blog Entries
- 1
silver- 99 ws6
lift
very nice lift I bet you're buddys are allways comeing over to see you and use the lift also.
I'd be useing a stool w/ wheels and be comfortable while under there.cam-LTs-FAST78-Susp.-Rims
10-25-2009, 06:28 AM #20Senior Member
- Apr 2008
- Madison, WI
Ok I have a question. The hoists we use at work have equalizer cables connected to each lift side so the hoist arms go up and down evenly. This hoist obviously doesn't have that. I know that when the cables break or are missadjusted our hoists lift crooked and are very difficult/dangerous to lower because one side usually goes down first and keeps on going and the cars almost fall off.
Does this hoist lift and lower evenly and smoothly?
I have a .630 lift...?
By MurderedOutTA in forum Internal EngineReplies: 15Last Post: 10-20-2010, 03:56 PM -
Question: Max Lift for CAM
By pmolina0436 in forum GTOReplies: 22Last Post: 01-08-2009, 08:34 PM -
how much lift is ok?
By TmaxicanA in forum Internal EngineReplies: 13Last Post: 03-06-2008, 11:06 AM -
Looking for a Used LS1 Cam 590 or less lift
By Regal Performance in forum Firebird / WS6Replies: 1Last Post: 11-01-2006, 06:44 AM -
Best cam for .600 max lift?
By phoenix1987 in forum Internal EngineReplies: 8Last Post: 10-01-2006, 09:41 AM
That was one expensive rear main seal!!! Looks like a nice setup man.
