    Gold Member - fadjur
    Melbourne, FL (the other Melbourne)
    2002 Trans Am Convertible
    P0300 P0171 P0174 code errors resolved
    Yesterday I found the culprit behind my P0171, P0174, and the latest one P0300. on my 2002 TA there was a hole/cut in the the small PCV tube going from the passenger front base of the intake manifold to the PCV valve.
    Symptom: rough idle, SES codes above at random times, once in a while stalling at idle-1/8 throttle, slight hesitation off the line. no problems at WOT.
    Solution so far: 2.5" of 3/8 braded fuel line and hose clamps to replace the 591 rubber grommet. dealer wants $111 for the hose because it's part of the whole assembly. The part is #591 on the PDF file -- it's part of assembly 565 ($111). The 550 hose was also suspect so I put hose clamps on both ends of that bad boy.
    Go to the LS1 folder and look at the PCV pics and dealer part page...
    http://public.me.com/solutionhost
    not sure how to upload pics here... so the link is all I got... Check yours out -- mine lasted to about 92K.
    Peace,
    Tony
    BTW: GMPARTS DIRECT has the assembly for about half the dealer cost:
    GM PART # 12590632
    CATEGORY: All
    PACK QTY: 1
    CORE CHARGE: $0.00
    GM LIST: $111.31
    OUR PRICE: $65.98
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Thats awesome! Thanks for getting on here and tell your problem/solution. These are fairly common codes, and it will help somebody sometime if they search it out. Glad you got it fixed.
    Quote Originally Posted by cold_surfer View Post
    Peace,
    Tony
    that's pretty common really. That's the first place I tell people to look if the symptoms sound like a vacuum leak. Glad you got yours figured out and thanks for posting.....will help someone else down the road.
    Mar 2010
    ATL
    2000 camaro z28
    throwin the 171 and 174!!! im tryin to fix my car today since i do not have work. im also throwin 704 which is the clutch switch and a 401 whicgh is egr insufficient flow. if any1 can get back to me that would b awsome. im going to replace the egr valve today and im trying to figure out how to bipass the clutch switch. im still tryin to figure out wat hose i got that has a leak. ruff idle some times. idles low if sittin at idle for over 2 mins..
  1. Codes P0171 and P0174
    By 00LS12LS6Z28 in forum External Engine
    Last Post: 08-28-2011, 12:38 AM
  2. P0171 and P0174
    By LSCyaL8R in forum General Help
    Last Post: 11-10-2010, 06:50 AM
  3. p0171-p0174 and 704 codes!!! help!!
    By maro1360 in forum Internal Engine
    Last Post: 04-20-2010, 06:21 AM
  4. Codes P0171 & P0174
    By tamu130 in forum Computer & Tuning
    Last Post: 09-15-2008, 06:33 PM
  5. p0171 p0174
    By SandmanWs7 in forum General Help
    Last Post: 10-23-2007, 11:56 AM
