Results 21 to 28 of 28
Thread: 02 z28 M6 error code help
10-26-2009, 10:52 AM #21Senior Member
- Dec 2006
- Deltona, FL
Sebring Silver Metalic- 2002 Camaro Z28
np, funny though. I followed the hose around and found the passenger side. I found a store that could order the AC Delco part. Then I was chatting with the guy at the store and dazed out while looking under the hood. When I came back from la la land I noticed the driver side staring me right in the face, lol...
I'm on the fence about tuning out the AIR. I already ordered the check valve, 30 bucks, piss. I guess I could just not accept it and do a return since it won't be here until tomorrow, Tuesday.
It is quite possible I will just see if I can find a tuner for the O2s and maybe do the AIR.
I'm not necessarily a tree huger, but I would feel bad taking out the AIR.
Does it really help that much?
10-27-2009, 02:09 PM #22Junior Member
- Jul 2007
- Maryland
I replaced both air pump check valves, also have O2 sims on the rear. By the way if heater circuit fails the only way to fix it is to replace the sensor, bad sensor. you can also troubleshoot by moving a known good sensor to the bad sensors location if code goes away then it was the sensor.
10-27-2009, 03:09 PM #23Senior Member
- Dec 2006
- Deltona, FL
Funny for a couple of hours today the SES light went out. I haven't checked it today but I am assuming it came back on because of the O2. The car was hot when it went out and came back on today, so I don't know if the AIR valve caused it.
I'm going to keep monitoring it with the scanner just to make sure it is still the harmless AIR and sensor 2 O2. I am so leaning toward tuning them out.
10-27-2009, 08:15 PM #24
The check valves in the air system were prolly shot until you replaced them. More than like you're just throwing the O2 code. Deleting the O2 and the Air is no big deal. I've been running without it for a while now. I even pulled the fuse going to the AIR system and now it's completely out of the car. To pass a visual inspection though I'd keep it all connected but just have the tuner delete them. The AIR just assists in warming up the cat and burning off excess HC and CO's at startup. The rear o2 if it dies your cat is still could cause all O2's will die lean. The heater ckt to the rear O2 is the most common code to throw in that system.
10-28-2009, 02:55 PM #25Senior Member
- Dec 2006
- Deltona, FL
Is there any way to clean the gunk out of those check valves?
The one seems to through a code, then clear itself, then trough etc.
The O2 stopped through codes. Its just the AIR check valve now.
I'm sure the O2 will come back to, but on my 99 I just got used to it coming and going as it pleased.
Owning your own little scanner makes it easy to just drop those annoying codes at you leisure.
10-28-2009, 09:37 PM #26
Yep. As far as cleaning the gunk, it's tough cause the check valves tend to deform or melt due to high exhaust heat. I'd just replace it completely. They're pretty cheap if you go to a pick and pool
10-29-2009, 01:06 PM #27Senior Member
- Dec 2006
- Deltona, FL
yeah i tried some sea foam, W-D 40, TB cleaner. It got some gunk out of it, but still sticks. I think the only thing i did was shave a couple of years off my life and skin cancer,
lol...sure the u-pull its seem to have no F-Bodies, or they have ravaged them to death.
One near me was bought out by LKQ and the ebay all their stuff like bandits.
10-29-2009, 01:53 PM #28Senior Member
- Dec 2006
- Deltona, FL
well i had the part paid and ordered, so i just broke down and decided to put it on. What the heck. I'm sure in a day or two I will need another one, lol....
P0430 error code
By 98TransAmWs-6 in forum External EngineReplies: 2Last Post: 10-15-2010, 10:21 AM -
Error Code P0125
By Spikito in forum Computer & TuningReplies: 4Last Post: 03-04-2009, 03:04 AM -
DIC error code P1416
By DaveC5 in forum External EngineReplies: 1Last Post: 05-15-2008, 03:54 PM -
P0430 GM Error code Help...
By in4sit in forum General HelpReplies: 0Last Post: 09-01-2007, 05:29 AM -
Help with error code
By THOMAS81Z in forum Internal EngineReplies: 2Last Post: 08-09-2005, 07:30 PM
