These engines don't have adjustable valvetrains from the factory,,,meaning the rocker arms are torqued to spec and that's it. The lifter preload and valvetrain geometry is set by the pushrod length.
You mentioned you installed new rockers, but didn't mention if you converted to adjustable or not. There are many kits out there that allow adjustability so you can set preload to a desired amount.
I don't remember if you mentioned replacing push rods either. The standard length seems to be in the 7.4" area, but I've been hearing that alot of shops are going just a tad longer now on the "NON" adjustable setups to quiet the lifter noise down a bit.
Not to mention also,,,,larger camshafts generally are ground with a smaller base circle (that's how the lift is obtained) which in most cases requires a longer pushrod anyway to get valvetrain geometry back in check,,,and also set proper preload on the lifters if your valvetrain is "NON" adjustable.
