    Mar 2015
    Ames, IA
    Monterey Maroon Metallic
    2002 Camaro Z28
    02 Z going for no prep glory
    I have a bolt on 02 Z/28 and run almost exclusively No prep stuff
    245 tire, best of 1.83 60' with a 3400 stall, non-adjustable founders rear suspension with LCA relocation brackets, umi torque arm, and competition engineering 3 way adjustable shocks. This was full weight (3740 with me in it) on an unprepped track.
    Hoping to go 1.60's with some adjustable front shocks and a diet on the same tire and surface.
    Any bolt on kings, or suspension gurus, your advice is welcomed!
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Welcome aboard. What type of tire are you running?
    Sent from my SM-G900V using Tapatalk
    Welcome! On a stock motor, 3200 stall, track tires, Koni D/A's up front, 3.73's in back, and all UMI underpinnings (including a tunnel mount torque arm), our car has laid down 60' times in the 1.6's on a prepped track.
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Quote Originally Posted by MaroonMonsterLS1 View Post
    How much are the wheels weighing in at?
    What do you set the tire presssure for?
    Do you do a little bit of burn to get the crap off ( not a full burn out) of the tires?
    Welcome to the site, Grady!
  1. Corvette + fireworks = so much glory
    By Ed Blown Vert in forum Corvette
    Last Post: 07-03-2015, 05:10 AM
  2. 1970 Pontiac Trans Am - Guts And Glory
    Last Post: 01-20-2011, 01:30 PM
  3. The Glory Of Owning A Firebird!
    By Aetos in forum Firebird / WS6
    Last Post: 07-14-2008, 07:46 PM
  4. Blades of Glory
    By KyleLs1 in forum Almost Anything Goes
    Last Post: 04-02-2007, 03:26 PM
