Results 1 to 20 of 23
09-13-2010, 11:53 AM #1
- Jan 2006
- Shepherd, Michigan
can high ltfts cause knock durring wot ?
can high ltfts cause knock durring wot ? logging my car i notice my bank 1 ltft and stft read higher and more active than my bank 2...and when i got wot i record up to 4 degrees of knock retardation ..could the possible exhaust leak be causing my ltfts to get scewed and retard timing durring wot ?
also my ltft sit at 25 quite a bit ...reason for concern ?
09-13-2010, 11:58 AM #2
YES large cause for concern!!
the exhaust leak (frash air that makes it's way to your O2 sensor) makes the PCM 'think' the car is lean and it will DROWN one side of the engine in fuel.
09-13-2010, 12:23 PM #3
- Jan 2006
ok that is what i thought...but since both ltft go 25 during light throttle or medium throttle but drops to like 15 during wot ..do i assume that there is a intake leak..since both banks are maxed..or just go after the one side that constantly reads higher when both arent maxed ?
sorry..i am still green with this...i understanding the logging and such..just not where to go with the info the logs give me
09-13-2010, 01:03 PM #4
- Thornton, CO
With what little I know about the LTFT's.....
You want them at zero.
25% adjustment is HUGE and as Frost mentioned....cause for concern.
09-13-2010, 01:07 PM #5
- Jan 2006
so basically it is safe to say i have a vacuum leak somewhere ...i am sure my tune isn't way off as it is frost's tune..oh well start with what i kinda know...more than likely i have a exhaust leak at the collector on the driver side..fix that and clear the ltft and re-log and go from there...am i right ?
09-13-2010, 01:13 PM #6
- Thornton, CO
Pretty much.
Easy enough to check for vacuum leaks....carb cleaner around the base of the intake and whatnot.
09-13-2010, 01:15 PM #7
09-13-2010, 01:17 PM #8
- Thornton, CO
Sure it would be fine....
Just make sure it can combust easily.
09-13-2010, 01:40 PM #9
Misfires 'look' lean to the PCM as well (unburned cylinder charge) and will cause the fueling to wander off positive.
09-13-2010, 02:46 PM #10
09-13-2010, 06:50 PM #11
- Apr 2008
- Madison, WI
this sounds familiar. Haven't you been plagued with running lean/ vacuum leaks in the past? I seem to remember you had some problems with your LS6 intake or something. Wasn't it cracked or what?
09-13-2010, 07:02 PM #12
09-13-2010, 07:03 PM #13
Stock or aftermarket MAF?
09-13-2010, 07:04 PM #14
- Jan 2006
even tho i have cleaned my maf and such..i wonder if my maf is not reading quite right ..or if my map is reading correct
09-13-2010, 07:06 PM #15
09-13-2010, 07:34 PM #16
09-13-2010, 08:02 PM #17
where is your exhaust leaking at? If it's before the front O2's I would get that fixed before going any further.
09-13-2010, 08:56 PM #18
Shady, email me a log. Include some WOT as well. I can tell you if the MAF is reporting low.
09-14-2010, 05:36 PM #19
10-04-2010, 02:11 PM #20
- Jan 2006
ok a update... i took off my driver side header...saw no leak..and the gasket looked good..so bolted it back up and then took my intake manifold off. There was a small leak in the back of the intake. so i JB welded that shit up ..but what concerned me was when i took my fuel rail off..my #7 injector was dripping fuel..i assume this is not normal..so now i need to address this issue to (maybe)
Help: high oil pressure, knock sensor codes, flat spot in accelera
By Stephen Thiede in forum General HelpReplies: 13Last Post: 11-26-2014, 03:33 PM -
knock knock...who's there? wait...engine knock...
By jiveass in forum Internal EngineReplies: 60Last Post: 04-26-2011, 08:04 AM -
knock sensor code with new knock sensors?
By zaaronz in forum General HelpReplies: 13Last Post: 02-27-2011, 07:26 AM -
Anybody know any good knock knock jokes?
By preston1980 in forum Almost Anything GoesReplies: 15Last Post: 07-22-2009, 02:35 PM -
knock sensor ect high temp?
By mr.5.7 in forum General HelpReplies: 5Last Post: 06-25-2007, 09:14 AM
