Thread: 98 z28 m6 3-4 shift grind
07-07-2016, 07:32 PM #1
- Jul 2016
- Brasher falls by
Hey guys , new to the forums here and the ls engines altogether . I built a 10 second 93 z28 years ago so I know the basis of what it takes to make these car handle power and put it down . My previous car was a 4l60 which I got real familiar with where as this old girl is 6 speed . I'm getting a grind when quick shifting gears between 3rd and 4th and I mm pretty sure that it's syncros. The sound seems to come right below the shifter . What's involved in fixing this issue and is there anything else it could be ? I want to fix this problem before I go mod crazy .. Thanks in advance
07-09-2016, 06:46 AM #2
If you are going to have to tear into the transmission anyway you may as well go through it and install upgraded parts where required.
07-13-2016, 12:19 PM #3
If it's a stock mc then you need to investing into a Tick Performance MC. Stock one at high rpm/rapid shifts are know to have issues. Something with the orifice not letting the fluid return fast enough.
There is a drill mod you can do but if you screw it up you're buying a new mc.
08-04-2016, 10:52 AM #4
You will also want to replace the 3-4 shift fork, that from the factory is aluminum and there is a TSB on them getting bent, with a steel one. I also had the drill mod done on my stock MC and it helped a lot.
08-04-2016, 01:43 PM #5
08-04-2016, 02:29 PM #6
that was years ago, my local dealer did a rebuild on mine in 2003 or 04. That was under warranty.
08-04-2016, 05:30 PM #7
Yup, the synchros, slider keys, 3-4 fork, rails and output shaft are all weak links of the T56.
Sent from my SM-G900V using TapatalkBoost gets you laid, unless your name is Jon.
why does it grind?
By TAallday in forum Manual TransmissionReplies: 8Last Post: 10-21-2011, 05:54 PM -
grind into 3rd
By mrmarcflo in forum Manual TransmissionReplies: 1Last Post: 04-27-2011, 08:50 AM -
1st - 2nd Grind
By garbs in forum Manual TransmissionReplies: 1Last Post: 07-20-2008, 07:28 PM -
Grind when shift into third
By The Gentlemen in forum Manual TransmissionReplies: 3Last Post: 02-02-2006, 04:55 AM -
1-2/2-3 grind
By Lextech1 in forum Manual TransmissionReplies: 10Last Post: 11-08-2005, 02:20 PM
