Results 1 to 20 of 31
    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    Aftermarket gauges.
    Hey guys I'll be ordering some aftermarket gauges for the ss.
    Oil pressure
    Vacuum
    And air/fuel pressure.
    I have no clue how to make em work.
    Can some one help me pls.
    Once I get this installed. I'll be looking at 3 more lol
    02 tahoe Z71 blacked out
    98 z28 red m6 sold
    07 zx6r ninja flat/black sold
    08 zx6r ninja sold
    May 2008
    Line Lexington, PA
    2002 z28 camaro
    Quote Originally Posted by 98maro View Post
    Oil pressure
    Vacuum
    What gauges, brand? electrical or mechanical?
    Where do you want to mount them? need more info to help you
    Feb 2010
    The brand is jdm. I got em on eBay.
    Oil pressure gauge.
    Oil temp gauge
    And vacuum gauge.
    The ones I'm gettin are not digital.
    They are mechanical.
    I'm goin to mount them on the vents for the a/c. I got dot done already.
    I just need to knw how to plug em or where to get the power from.
    When they are off. U can't see anything, the lights come on when the switch is open.
    I hope this helps.
    Thank u for the help
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    HERE you go.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Why a vacuum gauge?
    Get the following:
    Wideband A/F Ratio
    Fuel Pressure
    Water Temp
    May 2008
    Line Lexington, PA
    2002 z28 camaro
    Pull the power from the fuse box buy the drivers door. Run a single power wire to a small junction box. Individually fuse them and common ground. Done.
    Ls1camino is right. those are the 3 you want.
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    If they are "mechanical" gauges, make sure you have a "metal" line for the oil temp, if you use a plastic line, sooner or later it is going to leak oil.
    SteveC
    Feb 2010
    thanks guys for the replies..
    vacuum i decide it cuz im gonna have enough room..
    im a get 6 gauges.. 3 on the side and 3 on the a/c vents
    fuel pressure
    and water temp im geting
    i already have oil pressure..
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Post pics when done.
    Feb 2010
    I will
    I'll be working on them on the weekend.
    I'll post some pix
    Feb 2010
    Need some help,
    To install the oil temp and oil pressure. I need something called, "oil filter adapter sandwich plate."
    Where do I buy that?
    I saw one on eBay. It says it's universal. Are they all the same?
    Thanks
    Veteran Blackbird WS6's Avatar
    van down by the river
    Need some help,
    Thanks
    http://www.glowshiftdirect.com/Oil-F...-Adapters.aspx
    this is the one Ron aka hi-po used
    http://www.ls1.com/forums/showthread.php?t=121134
    Auto Painter RyanJM's Avatar
    Houston, TX
    I like that plate I just ordered one for my car, cheap amd a lot easier than the old days.
    I plan on doing autometer electric since I have had good.luck with them and I need white face with a red glow to get the closest march.to.the overlays.
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
    Feb 2010
    Quote Originally Posted by Blackbird-WS6 View Post
    thanks bro
    its cheaper than ebay
    Feb 2010
    one more thing..lol
    i need to get power from them.. i really dnt knw how to play with the fuse box... im thinking bout gettting the power from the day running lights.. is that a good idea??
    Feb 2010
    it took me a while to post pix of the gauges installed.. because i was waiting for some parts..
    ill be doin this tomorow after work..
    ill post pix of them when they are already connected..
    few pix bout the progress..
    the oil filter with the spacer and sensors,,
    its to dark but ill post pix tomorrow..
    i just couldnt wait to see them on the dashboard lol
    Laurel, Maryland
    2000 Grand Prix GTP
    one more thing..lol
    There is a port on the fuse box labeled "IGN". Take a blade connector (pictured below, top left), crimp your power wire (that splits later to go to different gauges) into it and push the blade into the IGN port. It will hold bery well and will not easily come out.
    Feb 2010
    Thanks bro I'll do that.
    Is fuse box on the engine bay right?
    Laurel, Maryland
    2000 Grand Prix GTP
    No, it's on the driver's side of the dash. Open the driver door and there is a little panel that is not visible if the door is closed. Open it and you'll see your fuses for lights and interior stuff.
    The engine bay fuse boxes are for stuff like your starter, fans, etc.
    Feb 2010
    Found it. Thanks bro
    So on that I'll get power when I open the ignition switch right?
  1. For Sale: Aftermarket gauges.
    By 98maro in forum Parts For Sale / Trade
    Last Post: 01-05-2011, 08:57 PM
  2. Aftermarket Gauges Needles question
    By squeals99 in forum Stereo and Electronics
    Last Post: 01-19-2008, 03:17 PM
  3. Aftermarket gauges question
    Last Post: 01-08-2008, 06:56 AM
  4. Lets see some pics of aftermarket gauges!
    By Secret Formula in forum Appearance Section
    Last Post: 03-24-2007, 02:33 PM
  5. Phantom Gauges,white Gauges(lt1),gauge Pod
    By onefastbird! in forum Parts Wanted / Trade
    Last Post: 11-19-2006, 03:20 PM
