Results 1 to 16 of 16
Thread: 2000 ws6 wheel spec
02-20-2008, 08:41 AM #1
2000 ws6 wheel spec
What are the specs of a 2000 ws6 17 rim?
Width? 9 or 9.5
Offset? 45 or 50
I would like to get these but not sure if correct size ( i want the exact size as stock)
http://buywheelstoday.com/products/T...hracite%29.bwt
02-20-2008, 10:24 AM #2
02-20-2008, 12:54 PM #3
- Oct 2006
- St. Clair Shores. Michigan
All Factory 17" F-body wheels are 9" wide and have a 50mm offset.
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
02-20-2008, 03:00 PM #4
well these work???
17 9 45 5-120.65
02-21-2008, 05:21 AM #5
02-21-2008, 01:17 PM #6
- Oct 2006
Yes they will work.
02-21-2008, 01:17 PM #7
Yea those will work but get them on ebay they will be much cheaper.
02-21-2008, 02:02 PM #8
- Apr 2007
- Newport, RI
Navy Blue Metallic- '00 Formy A4
Check TomzWheelz. I saw on LS1 Tech that they're running a special on the TTM's, looks like great prices.
02-21-2008, 07:38 PM #9
- Jun 2002
- Montreal, CANADA
stock is 17x9, +50mm offset
Yes those will work, having the wheels stick out 5mm relative to stock ones.
5mm = 0.2"Eugenio_SS
02-22-2008, 05:37 AM #10
02-22-2008, 05:37 AM #11
03-28-2008, 06:22 PM #12
- Mar 2008
- Calgary,Alberta
I was wondering why these rim guys keep saying the 120mm bolt pattern fits the 4.75" Are any of you running the wrong bolt pattern without issue?
here is an example.
http://cgi.ebay.com/ebaymotors/18-Co...RCHQ3aUSQ3a101
03-29-2008, 04:31 AM #13
03-29-2008, 05:56 AM #14
- Mar 2008
- Calgary,Alberta
I thought it would work just didn't want to get the rims and then find out it wouldn't fit properly. I guess the difference is less than a spark plug gap.
Thanks
03-29-2008, 08:10 AM #15
- Oct 2006
Each lug will be .32 mm off and that is within tolerance levels.
The biggest issue is that most of these wheels with the 5x120mm pattern are Lug centric where the factory GM wheels are Hub centric.
The best Advice I can give you is to get some Hub centric rings. I have them and have never had any problems.
03-29-2008, 12:30 PM #16
- Mar 2008
- Calgary,Alberta
Thanks, I'll check into the rings.
2000 5.3 trigger wheel?
By Sleeper101 in forum GM TrucksReplies: 0Last Post: 12-09-2010, 05:53 PM -
2000 camaro wheel hopping
By flash46 in forum Suspension and HandlingReplies: 6Last Post: 04-12-2009, 09:13 AM -
Wanted: Wheel to match my 2000 WS6
By stevenm357 in forum Parts Wanted / TradeReplies: 0Last Post: 06-24-2008, 06:29 PM -
LS1 Fidanza Alum Fly-Wheel Spec Stage 3 Clutch
By tlgphoto in forum Parts For Sale / TradeReplies: 2Last Post: 05-08-2008, 08:15 AM -
FOR SALE(2000 Z28 Wheel/Tires)!
By Trouble maker in forum General ClassifiedsReplies: 1Last Post: 01-21-2006, 09:42 AM
