Results 1 to 11 of 11
03-08-2010, 05:29 PM #1
- Mar 2010
- Saskatoon, Saskatchewan
White With Blue decals- 1999 30th Trans Am #0922
Window electical problem. New to Site
Hi, I am new.. so bare with me here.. I have a 1999 ws6 Trans am. And i went to get it safety, and when we took it in the windows worked fine now problem going up and down. We get a call saying it failed for other reasons but the windows would not got down. So it failed for that.. So we got the car home and just held the window button down and turn the key on and off and it started too work. Was just wondering if anyone had this happen to them or know of a thread I should look into. Thanks for the help and i will answer any questions if i left some stuff out. Thanks again guys.
03-08-2010, 05:40 PM #2
- May 2009
- college station, tx
sold: 1999 firebird- 1998 Trans Am
does it go really slow when it is working? probably your motor, $50 at autozone with a lifetime warantee.
was money well spent for me...
03-08-2010, 05:41 PM #3
- Apr 2008
- Madison, WI
It might be the common BCM problem. Here's a good write up on it:
How To Fix Intermittent Windows, Radio and Locks/
Also one of our sponsors has an excellent window fix kit if your passenger window moves slowly
AutoTrix window fix
03-09-2010, 08:49 PM #4
03-25-2010, 09:50 PM #5
- Mar 2010
Got to the BCM and the it had a cold solder joint on one of the spots it said to check. Reflowed it and the radio has not cut out once since then. My pass window will stop working for no reason off and on though. Anyone know what might be causing it? I am thinking wiring.. but not sure.
03-25-2010, 09:52 PM #6
Could still be the motor.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
03-25-2010, 10:03 PM #7
- May 2009
like i said, the motor
03-25-2010, 10:10 PM #8
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
The passenger window is a problem for us all. Unfortunately the way GM wired our cars we typically burn out passenger side motors alot.
Like Cutlass said give this a try AutoTrix window fix
03-26-2010, 11:15 AM #9
You will most likely need to replace the motor. Like everyon has posted above GM's piss poor wiring kills our passenger motors. Get the window fix and new motor and do both at same time. You will see a difference.
03-26-2010, 03:28 PM #10
03-27-2010, 09:26 AM #11
- Mar 2010
Thanks for the posts dudes, I will have to save up some cash for the window and motor fix. Looks pretty highly recommended on this site so that must mean it works.
Another window problem
By Firebirdformula in forum Stereo and ElectronicsReplies: 4Last Post: 06-19-2010, 12:07 AM -
I have a serious problem with someone on this site
By JHayesLS1 in forum Almost Anything GoesReplies: 21Last Post: 01-16-2009, 10:31 PM -
Window problem
By Sas in forum Firebird / WS6Replies: 6Last Post: 10-20-2008, 12:28 PM -
window problem
By blackz28ls1 in forum General HelpReplies: 6Last Post: 08-03-2008, 07:43 AM -
Freakishly odd electical problem...
By DADillac in forum Stereo and ElectronicsReplies: 10Last Post: 11-28-2006, 08:53 PM
