Results 1 to 20 of 24
03-24-2007, 06:47 AM #1
- Feb 2007
- Temple Texas
Silver- 2000 WS6
Compression ratio for Supercharged LS1?
Any body know the ideal compression ratio for an 02 LS1 that will be supercharged at 8-10psi? Still doing my home work. Anybody ever deal with MTI or HPE out of Houston Texas?
03-25-2007, 05:16 AM #2
- Apr 2001
- Surf City, NC
Black/Screaming Yellow- 99 S/C TA WS6 & 04 Cobra
I would say around 9.0 to 9.5:1 for the compression ratio. I have dealt with MTI before!
03-25-2007, 05:49 AM #3
- Feb 2007
- Temple Texas
Silver- 2000 WS6
I take it that they did not live up to there advertisement? What went wrong and where would be a good place to go for an engine built to my specs? Thanks for your help.
04-17-2007, 11:34 AM #4
I would agree with the 9.0-9.5 compression.......It should be safe with those levels at that compression.
04-17-2007, 06:18 PM #5
- Feb 2007
- Temple Texas
Silver- 2000 WS6
Thanks for the reply, any other advice you care to give for a supercharged ls1?
04-18-2007, 05:34 PM #6
- Apr 2007
- Bellingham , WA
89 porche Red- 1970 Camaro RallySport
Hi, im new here but iam very knowlegeable. I have a engines book and it has a chart in it. it goes by COMP ratio to PSI of boost. so if a stock LS1 has 9.0 or 9.5 with 8 PSi of boost you will have a 13.9:1 Compression ratio with 9.5 u would have a 14.7 comp ratio. its a pattern more boost higher compression ratio's but you would be safe with 9.0 but i think thats the limit you. with this compression ratio you will have to run at least 100 octane. this is why lower intial compression ratio is better for turbos and superchargers
04-19-2007, 03:03 AM #7
then how would you run a vehicle at fourteen to sixteen pounds of boost? According to your formula, you would need rocket fuel to be able to do that. There are people here that run a 8.5 CR and go double digit on the boost and use nitrous. How is this possible with the formula of your book? Lots of people run six or seven pounds of boost on the stock CR, on pump gas. What does your formula say about that?
04-23-2007, 02:52 PM #8
Most seem to run in the area of 9.0-9.5. I would think trying for 9.0 would be a little safer and maybe even give you the chance to expand a couple of lbs in the future if you wanted to.
04-23-2007, 03:14 PM #9
- Aug 1999
- Arizona
The stock 10:1 could handle 8#.
But 9.0-9.5:1 would be better.
I am running 9:1, but I plan on running 10-15# of boost.Black 1999 Blown Convertible A4
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
05-23-2007, 05:42 AM #10
this is a dumb question but could i ever look at running pump gas with a s/c at 9-12 or really 9-15 lbs of boost
05-23-2007, 06:09 AM #11
05-23-2007, 06:59 AM #12
05-23-2007, 07:33 AM #13
hey Ed my 402 ls2 is 11:1 just like LS7 motor, I guess they'd have to forge it to bring the CR to 9s then put a s/c? just curious, perhaps a project in 2 years from now.
05-23-2007, 07:41 AM #14
05-23-2007, 07:44 AM #15
05-23-2007, 07:54 AM #16
05-23-2007, 07:55 AM #17
and that gave you what rwhp gain at 5#?
05-23-2007, 07:57 AM #18
- Aug 1999
- Arizona
I think it was 100 rwhp
05-23-2007, 08:00 AM #19
it's definetely worth it. the procharger goes for 4-5k?
05-23-2007, 08:01 AM #20
I gotto ask Santa Claus to be nice for next year, this year putting money in the sock for a house perhaps by April next year...
Compression Ratio
By Bouvers in forum Internal EngineReplies: 42Last Post: 01-12-2009, 01:56 PM -
compression ratio question
By silverz28camaro in forum Internal EngineReplies: 1Last Post: 08-05-2007, 09:49 PM -
compression ratio?
By wesTXwitesnake05 in forum Internal EngineReplies: 1Last Post: 07-09-2006, 10:29 AM -
compression ratio ?'s
By cannotbeheldliable in forum Forced InductionReplies: 1Last Post: 04-13-2006, 10:26 AM -
What Compression Ratio
By JD_Z28 in forum Forced InductionReplies: 6Last Post: 03-18-2006, 04:11 PM
