View Poll Results: Seafoam a good or bad idea???
- Voters
- 89. You may not vote on this poll
Yes, its a bad idea.
16 17.98% -
No, it works great!
73 82.02%
Results 41 to 60 of 92
Thread: Seafoam good or bad??? Poll
05-11-2010, 05:23 AM #41
Yeah OK!
Not to mention the Shit Ass PVC system that Most Never modify to stop from sucking oil through the motor on a regular basis. . . . . . . . But I guess that doesn't matter if it's "good" oil right? Then it doesn't cause build up on the piston face or cause the rings to stick. . . . . . . . .Don't be afraid of the bottle!!! Be afraid of your tune!!!
05-11-2010, 05:57 AM #42
- May 2009
- Toronto
SOM- 2002 SS
I would rather do that then pour piss in my motor because it makes it smoke. Just because your pouring chemical cleaner in there doesn't mean you aren't harming everything else In your motor. One instance of detonation from pouring that snake oil in there and much more harm than good and for me not worth the risk. I've seen motors taken apart with up to 1.2 million miles and they're clean inside. No need for gimmicks and relying on people to fall for bs advertising to make a buck.
If your motor is THAT dirty inside go get a real tune or fix why you Are getting carbon buildup in the first place.
LOL point proven my rear end. By whom an Internet expert ?? Most if you are all the same people who bought slick 50, tried an airfoil and used splitfire plugs when they came out. Oh wait I best most are buying iridium now ...
05-11-2010, 06:06 AM #43
- May 2009
- Toronto
SOM- 2002 SS
05-11-2010, 06:07 AM #44
Because LS motors don't use a PCV Valve they have a hose that sucks oil mist from the lifter valley through the throttle body and through the intake into the combustion chamber. Burning that oil Non Stop over the years will cause Unwanted build up regardless. You can take a stocker and do a compression test then SeaFoam and do it again and it will have increased cylinder pressure due to freeing up the ring packs that were all gummed up with burnt oil.
I speak of personal knowledge Not some hokis pokis;
I build cars and engines for a living and have for over a decade now.
And your latest comment . . . . . How the hell you think you would know??? LOL
I SeaFoamed that high 13 second car you got NOW!
05-11-2010, 06:31 AM #45
- May 2009
- Toronto
SOM- 2002 SS
05-11-2010, 01:49 PM #46
- Mar 2010
- St Pete, FL
Bat mobile black- 2000 Trans am WS6 M6
where exactly do u enter this stuff into the motor?
05-11-2010, 02:08 PM #47
Usually suck it through the vacuum hose going to the brake booster.
05-11-2010, 02:09 PM #48
05-11-2010, 02:55 PM #49
I respect your opinion but I disagree with you This isn't a snake oil like many would believe, Ive ran it in both my cars at this time (4 total) and had no problems. Does it help....I think so since I did it right before my H/C build and my motor was spotless, but is it the best ever.....I can't argue
05-11-2010, 04:11 PM #50
- Mar 2010
- Carrollton tx
Dark blue/ Green- 02 ss 35th/99 z28 camaros
I work at autozone and some pepole only buy it and live by it i have used it and it works
05-11-2010, 04:53 PM #51
- Apr 2010
- Alpharetta, Ga
04 Cobra 'vert - M6 mysti- 02 WS6 coupe - A4 red
Getting a tune may prevent further buildup, but I'm pretty sure it will not remove the carbon that is already there.
Do you get off on being assy to us poor noobs? I guess you were born knowing everythign about cars? Thank you for sharing your wisdom with us, but why don't you try sharing it in a more friendly, professional manner? Pretend for a moment that you were NOT, in fact, born knowing everything... thanks...
05-11-2010, 04:55 PM #52
05-11-2010, 05:00 PM #53
- Apr 2006
- Charlotte, NC
Hugger Orange/W stripes- 1999 Z28 M6
I've used it and feel it was beneficial, but I still cannot bring myself to add it to the oil. Vacuum line and gas, okay, but I just can't see it as an oil additive I'll use.
05-11-2010, 05:03 PM #54
05-11-2010, 08:19 PM #55
- Thornton, CO
It is a lubricant.
But given that, you DO NOT want to leave it in the oil for long. I use it, but drive no more than 25 miles with it in the oil.
When I use seafoam, I use an entire can throughout the motor.
1/3 in the oil before an oil change.
1/3 in the fuel before a fill up.
1/3 in the brake booster right before the oil change.
That said....why in the hell is this thread back around anyways?? This was started a while back.2008 Trailblazer SS
Lowered, HID's, tinted.
05-11-2010, 08:38 PM #56
- Jul 2009
- Charleston, SC
2010 Nissan Sentra SR dd- 2001 Pontiac Trans Am WS6
I have a '95 Mitsubishi Eclipse RS. It has a crappy 2.0 4cyl in it. The thing burns oil like there's no tomorrow. I have to add a quart a week. The car itself has 243,000 miles on it but the engine is a replacement. I've put about 30,000 on this engine, but my uncle got it used and I have no clue how many miles were on it before. I think I have a stuck lifter. I know something in it is ticking. I'm in the process of fixing my T/A and it should be ready to go soon. After that, I'm planning on rebuilding the engine in the Eclipse and then probably selling it. Would it be safe to use seafoam or that AutoRX stuff on that engine right now to hold me over until I get my T/A done or would it completely disintegrate the remaining stuff in my gaskets?
05-11-2010, 08:47 PM #57
05-11-2010, 09:26 PM #58
05-11-2010, 09:34 PM #59
05-11-2010, 11:00 PM #60
- Thornton, CO
Not disagreeing....but have you used it?
No experience with it personally, but I would assume the reasons why people say not to use Seafoam or change to synthetic oil after a certain amount of miles would apply to AutoRX.
To be clear, this is NOT a knock on aforemetioned product.
Seafoam cleans EVERYTHING.
Similar reason to why some say not to switch over to synthetic after a certain amount of miles.
Just in case.....at least as far as my opinion goes.......
Seafoam?
By Ramairgod84 in forum General HelpReplies: 15Last Post: 04-13-2010, 01:27 PM -
Question: SeaFoam
By WhatUpWhatUp in forum Showcar and DetailingReplies: 21Last Post: 03-10-2010, 07:56 PM -
Seafoam
By David Ray in forum General HelpReplies: 26Last Post: 05-31-2009, 05:49 PM -
Poll: Stairway to heaven good ring tone?
By Hurley711 in forum Almost Anything GoesReplies: 17Last Post: 12-15-2008, 08:15 PM -
Seafoam
By chuckie669 in forum Internal EngineReplies: 76Last Post: 08-07-2008, 04:18 AM
