Thread: Catalyst insufficient code??
07-18-2008, 11:48 AM #1
Has anyone ever heard of this? if so what does it mean.
07-18-2008, 02:06 PM #2
Exhasut leak maybe
The catalyst monitor d-agnostic and is sensitive to several conditions,
-exhaust leake
-HO2s contamination
-alternative fuels
In the exhasut system leaks may cause the following
-prevent a degraded catalyst from failing the diagnostic also a failure for a normally functioning catalyst and prevent the diagnostic from running.
But somewhere in the exhaust is causing the diagnostic from running that would be my quess. That may be what you are seeing
07-18-2008, 06:15 PM #3
do you have hi flow cats or no cats? that would cause it
07-18-2008, 08:49 PM #4
I'm guessing it's a p0420 or p0430 code? Could just simply be you have a bad cat.
1972 Chevy Nova Fitch Fuel Catalyst Install - CHP
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 03-27-2009, 10:20 AM -
Sarge call out(fitch fuel catalyst)
By JoshieDoom in forum Almost Anything GoesReplies: 11Last Post: 06-02-2008, 01:28 PM -
Catalyst Monitor Not Ready? Secondary Air ?
By Patsy57 in forum Computer & TuningReplies: 12Last Post: 04-04-2008, 09:21 AM -
Check engine light. P0430 code catalyst system efficiency bank 2. Question?
By Rob00Taws6 in forum General HelpReplies: 3Last Post: 08-19-2007, 03:12 PM -
Those with "Catalyst low efficiency bank X" MIL's...
By emarkay in forum General HelpReplies: 4Last Post: 12-10-2006, 12:29 AM
