Results 501 to 518 of 518
Thread: I need your dyno numbers
07-10-2013, 03:56 AM #501
07-10-2013, 04:23 AM #502
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
Check my Sig.
Callies 383, Trick Flow 225, Rapid Motorsports Dominatior 2 X cam, ls6 ported oil pump,42lb injectors, FAST 92/92 , ASP underdrive pully, eletric water pump, Pacesetter LT's, Pacesetter ORY, Magnaflow catback, e-cutout, Yank SS 3600, Performabuilt stage 2 4l60e, Strange S60 ,4.10s, Detroit Truetrac, (UMI) - Adj. LCA, Adj. tunnel mount torque arm, Adj. panhard bar, Drag bar, subframe conectors, shock tower brace. 465rwhp-438rwtq 11.09@119.90.
07-10-2013, 06:03 AM #503
What's the new mod that netted you another 35hp?
07-10-2013, 06:31 AM #504
- May 2010
- Wilkes-Barre, PA
Trick flows and a bigger cam.
07-17-2013, 05:57 PM #505
615/540...peak power @ 6700....N/A....thru a 9"....thru catted duals.
Mustang dyno.....have a few more in it, more to come.
12-01-2013, 02:20 AM #506
Nrceptr--Z28 Hardtop--2001/A4--11/24/2013--DynoJet--298 rwhp--317 rwtq---N/A, Blackwing lid, SLP bellow.
12-24-2013, 07:48 AM #507
Done
05-10-2014, 01:45 PM #508
Mike0202 - WS6 - 98/m6 - 5-10-14 - MD - 423/386 - NA
05-10-2014, 05:38 PM #509
1998 TA. Dynoed 5/2/14 and it did 330 hp 345 torque. Kooks headers,kooks ORY, Corsa Catback and SLP lid.
2001 B4C Camaro
LS1 lid
Speed Engineering 1-7/8 headers and y pipe
Borla Catback
SOLD!!!
1998 Trans AM M6
Corsa Catback,Kooks 1-7/8 Long tubes,Kooks 3 inch Y-Pipe with High Flow Cats, MGW shifter, 4:10's
05-13-2014, 03:16 PM #510
Done.
Roger, I just assumed you used a Mustang dyno, please correct me if I'm wrong. I added you to the list.
05-13-2014, 03:21 PM #511
- Oct 2008
- Coral Springs, Fl
Tatertot91 --- Camaro --- 2001 M6 -- 5/13/14 -- Mustang Dyno -- 469 RWHP -- 430 RWTQ -- N/A
05-13-2014, 03:32 PM #512
Done
09-30-2014, 02:25 AM #513
Werewolf --- Z28 1SC--- 2001/6sp-- 09/29/14-- Mustang-- 340.9 HP(367.5 wcf) -- 350.9lb/ft(378.7 wcf)-- N/A, K&N FIPK, TSP Long Tube 1 7/8 in headers, TSP ORY, and Magnaflow cat back with HP Tuner programming.
10-01-2014, 02:43 PM #514
wcf?
10-01-2014, 08:02 PM #515
10-03-2014, 02:47 PM #516
Couldn't it be "want correction factor"
I hit 350rwhp... but I want 400
Done... with the actual numbers.
2018 Tahoe - Silver - OEM
10-03-2014, 11:57 PM #517
yea I think that is an acceptable description also lol. Trying to find out how the numbers really work out but either way I am at the high side of what I expected or way above what I hoped for. Now how this all ends up affecting my ET at the track.
03-11-2018, 03:04 PM #518
- Apr 2006
- NW Ohio
2004 Black Escalade EXT- 1999 Hugger Orange Z28
99 z28 - 408 - 449rwhp - 459rwtq
99 Hugger Orange Z28 A4 3.42's
Mod's Livernois 408, SLP Cold Air Intake, Pacesetter LT's, ORY, Electric Cut-out, Magnaflow Exhaust, Finish Line Level 5 4L65E, Vig. 3200 Stall, Spohn LCA's, UMI SFC's, Broken 10 bolt, 17x9.5 and 18x10.5 Black Z06 Motorsports
I want dyno numbers
By 2K2SLPSS in forum Mid-West MembersReplies: 0Last Post: 10-13-2010, 05:41 PM -
LOW dyno numbers?
By 05gtoautoX in forum GTOReplies: 11Last Post: 10-27-2008, 11:34 AM -
Tr230 dyno numbers 98 heads=bad numbers?
By phoenix1987 in forum Dyno InformationReplies: 7Last Post: 09-11-2007, 08:33 AM -
dyno numbers
By imprtkillr2810 in forum Firebird / WS6Replies: 1Last Post: 03-28-2007, 07:33 PM -
Cam Only Dyno Numbers!!!......236/236
By Demonicbird00 in forum Eastern MembersReplies: 0Last Post: 08-08-2006, 08:11 PM
