Results 1 to 20 of 27
10-23-2006, 09:55 PM #1
Lost to a Mustang leaves me scratching my head.
Ok, I lost to a '99 Mustang GT. We only went from a dig to 60-70 MPH, but 1st time I lose about a car-length, 2nd time it was dead even. I'm going nuts thinking something is potentially wrong with my car, or one of my mods put me back. The only time I lost a little control was the 1st to 2nd shift the 2nd run...my tires smoked a little and I felt like I was on ice for a second or 2. On a Mustang forum they're calling me a bad driver, but it's a fucking A4. Here's the specs on both of us.
99 Gt 98,000 miles M5 2v 3.73 gears ,alum d/s , Uca+Lca's, 99 Cobra wheels, LOUDMOUTH Catback , Dr Gas X, Accufab T/b + Plenum ,Wingless , Scoopless , and Debadged ..one and only dyno run = 87 pump gas, factory tune, with mods listed and a cold motor 239rwhp@5000rpm 266.8rwtq@4100rpm
00 Z28 64,000 miles A4 3.23 gears, K&N FIPK, Hooker cat-back, TB Coolant Bypass, Jasper Class 1 4L60E. Ran 91 octane.
How could I lose??? From the factory I should've had 298 RWHP and 335 RWTQ, guessing @ 310 RWHP and 345 RWTQ modestly.
10-23-2006, 09:57 PM #2
10-23-2006, 10:02 PM #3
Oh yea, and if you think somethings wrong with my car...well.
The alternator, water pump, thermostat, fan belts, coolant (Dex-Cool to traditional green), sway bar bushings & links, ignition cylinder key, pads, rotors, battery, and transmission are all new within the last 15,000 miles.
Tires are going a little but still have tread on Goodyear Traction T/A's. Shocks are dead but who cares on a drag.
10-23-2006, 10:13 PM #4
10-24-2006, 04:42 AM #5
- Sep 2005
- NJ
Racing to only 60-70 is pretty lame. Thats not even the 1/8th mile. Go higher next time and youll pass him without a doubt.
10-24-2006, 06:31 AM #6
- Dec 2005
- Research Triangle Park, NC
Pewter- '99 Z28 M6
I agree. You should have run up to 100 mph. Short races are all about traction. A street race usually involves bad pavement, furthuring your traction problems.
I ran a couple GT's with the Cobra from a dig, and I was usually behind out the hole, but once 80 mph it was bye bye.
Bigger tires, better launch skills, and you will have short races in hand also. But if traction is an issue, you will need to run up to 100 mph to put him in the rear view handily.Last edited by Roastem; 10-27-2006 at 03:08 AM.
Heads 'n Cammed, Moser 12, 3.73's, Weight Reduction, 13" Brembo Kit
BMR track suspension, full exhaust, the works...
412whp/394wtq 1/4 mile slip coming soon!
Gone: '01 Laser Red Cobra 3.73's/Full Bolt-ons
10-24-2006, 07:07 AM #7
Eh, but the other guy didnt really have any traction problems. The pavement under their tires were equal. Plus, its kinda hard to fuck up an a4..unless he panic-ed and hammered it after the guy started to win the launch.
However, YES. I agree that that is a SHITTY mph finish 'line.' Thats less than 7 seconds. (hopefully)
Either race correctly or not at all.
10-24-2006, 07:21 AM #8
sucks but here's why you shouldn't take it so hard. everyone knows that mustangs have great low end/out of the hole power. it's their power to weight ratio/gearing. couple that w/a 5spd and after marktet 3.73's and its a good combo for them. I also agree that racing to only 60-70 is in the perfect range for a mustang to get an LS1 car, but anything over that, it's going to be all LS1...
10-24-2006, 08:06 AM #9Ratdaddy07Guest
Not to mention reaction time could be huge in such a short race if you wanna call it that. Run him again for real this time, go for 4 or 5 telephone polls or pick an end point, if it ain't at least close to a 1/4 mile it ain't racin to me.
10-24-2006, 10:13 AM #10
Post a link to the stang board
10-24-2006, 10:21 AM #11
I read the story on the SVT board before I did hear. I was the guy who posted you needed the driver mod because you should be able to smoke that guy.... I think your probably just spinning the tires and not getting out of the hole like you need too. What tires are you running on? Get some decent drag radials and redeem yourself then race that guy again.
10-24-2006, 11:00 AM #12
10-24-2006, 11:08 AM #13
- Jun 2006
- bay area california
black on black on black- 02 z28
well you probly cant drive....ha ha that sucks
10-24-2006, 04:06 PM #14
I lost to a 05 gt a couple weeks ago also.It's all in the traction.I had bald tires at the time. Once I hooked I started to reel him in but we were out of the gas before I could catch him. Got tires and am now looking for him.
10-24-2006, 05:50 PM #15
Is it possible that the guy is not being totally truthful with his mod list? my brother has a 99 GT and the mods he has are all internal. At first you just think you are looking at a basically stock 4.6L until you run him and hear his car rapping out to almost 8000rpm's.
10-24-2006, 06:14 PM #16
- Oct 2006
- Sneads Ferry, NC
- 2002 TA
Or a little of the funny gas as well, I can't see him beating you, even if you were spinning through all the gears.
10-24-2006, 07:04 PM #17
- Oct 2006
- Delray Beach
Black- 2004 Mustang GT
i have a setup alot like that but without the gears. cars like this are faster than you think. mid 13s at around 103-106. good enough to run with a stock ls1 car.
10-24-2006, 07:05 PM #18
- Oct 2006
- Delray Beach
PS dont forget the GT is only 3283lbs in 99.
10-24-2006, 07:17 PM #19
Thats all I can say
10-25-2006, 07:28 AM #20
- Jan 2006
- Michigan
Red- 02' Z28 M6
I put 4 car lenghts on a 98 cobra from a 70-120 roll at least 3 times....I am close to stock too.
Just Scratching The Surface
By Ed Blown Vert in forum General HelpReplies: 0Last Post: 08-09-2012, 12:30 PM -
scratching noise---throwout bearing?
By jmatt07 in forum Manual TransmissionReplies: 1Last Post: 01-30-2009, 06:27 AM -
HELP. windows scratching
By stefos in forum Firebird / WS6Replies: 4Last Post: 10-18-2007, 07:04 AM -
scratching windows
By stefos in forum General HelpReplies: 8Last Post: 10-15-2007, 08:59 AM -
4th gear scratching...
By LS1 SEAN in forum Manual TransmissionReplies: 7Last Post: 11-27-2005, 09:21 PM
