07-21-2006, 09:22 AM #1
- Oct 2005
- Knoxvegas, Vol country Tennessee
Sebring Silver- 98 Z-28 camaro
Throwing some codes, more problems
P0102
P0103
P0134
P0140
P0151
P0160
P0405
P0650
I'm getting 11 codes on this car, found out the check engine light bulb was blown but what the hell can cause all this B.S.
I realize the rear O2's are not detected because I never bought a O2 similator but what's the deal with the front two? The parts guy down there said my computer is running in a limp mode since the front O2's aren't working, also it's throwing a MAF code. I wander what's wrong with it. The car is running fine besides running extremely rich, it revs kinda funny too but it still shit's and gets whenever I mat it. I'm going to delete the EGR and rear O2's out of the computer. Thoughts on this?
07-21-2006, 11:41 AM #2
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
102 & 103- try cleaning the maf and the sensor contacts. if that doesn work, you may need a replacement maf (if you know someone local, ask if you can borrow theirs to test it out)
delete the rear o2's and the egr. that'll clear the b1s2 and b2s2 codes as well as the 405.
650-the mil light needs to be fixed.
Did you just install headers? Do you have cats? Need more info on your mods. for both banks to just die like that isnt normal. Either they're not plugged in if you did a header install and thats why you're not seeing any activity or...i dont know...ill have to think about that one...
07-22-2006, 04:43 AM #3
- Oct 2005
Thanks, I installed the headers a while back and never got the O2 sims for the rear but I did buy the extension harness for the front two. I deleted the cats with the ORY when I did the header install, I have ceramic coated LT's.
As far as the MAF, it's confusing me that it would be pulling a low frequency and high frequency code. I bought some electrical contact cleaner so I'm going to try that and clear the computer again to see what happens. How hard is it to change the check engine light bulb? Looks like the whole dash pad has to be removed in order to get behind the instrument panel.
07-22-2006, 09:12 AM #4
- Aug 2003
- Honolulu HI
dont know about changing the light. never heard of it going out..i havent ever looked into it either. you may wanna check your connections. you're not getting any input from your front o2s at all, so either the extensions are causing problems for its not plugged in correctly. The maf, just unscrew the torx screws to remove the ends so you can have access to the front of the elements. be very careful when cleaning them. use a qt to do it, but be gentle.
07-22-2006, 09:39 AM #5
- Oct 2005
Thanks for the help, I'm going to tear into it after work today
07-22-2006, 12:58 PM #6
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
The maf and front o2 codes are probably related. . .
07-22-2006, 01:14 PM #7
- Aug 2003
- Honolulu HI
but he should at least get shotty readings from the o2's showing they're reading wrong, not them just die. I think it may be related to the header install.
Help: Starting Problems and Throwing Codes
By SOCAL WS6 in forum General HelpReplies: 8Last Post: 09-14-2009, 01:43 PM -
Question: Throwing Codes
By TheChad1371 in forum General HelpReplies: 1Last Post: 07-24-2009, 04:11 AM -
Question: Throwing a lot of codes
By JoshieDoom in forum General HelpReplies: 5Last Post: 03-14-2008, 05:01 AM -
Need help, throwing codes!!!
By rotwiler in forum Computer & TuningReplies: 2Last Post: 07-13-2007, 08:44 PM -
Throwing Codes
By T/Ajammer in forum Computer & TuningReplies: 2Last Post: 09-12-2006, 05:52 PM
