Hello new to site. Had a question on a 2001 t56 behind a LS1 changed the factory clutch, pressure plate, hyd throw out bearing, and pilot bearing. I had the flywheel turned. Installed this and the trans doesn't go into reverse right away then grinds going in. I know reverse isn't synchronized. We've re-bled no air. Other than a new part problem we are trying to figure out why the hyd part doesn't push out far enough to fully disengage the clutch. maybe some one had this happen and can help.
