Thread: Synthetic oil after 100k
06-19-2016, 05:35 PM #1
- Jun 2012
- florida
Is it ok to switch to synthetic after 100k miles. I have a new job where I drive to work an hour early way 70-100 mph so i am thinking of a better oil. And if I change over what should the change interval be?
06-24-2016, 02:08 PM #2
Perfectly fine to switch at any time. I run Amsoil 5w30 in my daily driver 2.2L. I do 5,000 - 6,000 intervals along with a tank of fuel system treatment ( Amsoil fuel system cleaner ). It's been a good 54,000 miles in 3 years with this combo.
2000 Trans Am WS.6 M6
SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
YouTube.com/DarrenWS6
06-24-2016, 05:40 PM #3
I run full synthetic and quality filters on our DD's with a 7,500 mile change interval.
06-29-2016, 05:24 PM #4
- Apr 2014
Pennzoil platinum and fram ultra oil filter on my dd with 159k
08-18-2016, 06:34 AM #5
- Aug 2016
- Merrick,NY
- 2001 WS6
I was skeptical because years ago I had a 1986 grand national and when I switched to Mobil 1 it started leaking oil like a sieve. If I was parked for a half hour I would have a 2 inch diameter spot under my car. For this reason I was a little bit hesitant, but my new (old) 58K LS1 had not been given an oil change in a little while due to the prior owner not driving her that much, so I dumped the Purolator filter and oil which didn't look bad for a mix of Castrol GTX and Castrol Magnetec 50/50 mix. I used the M1 oil filter and my pressure jumped 20 pounds at idle from roughly 20 to 40 PSI. No leaks so far but I probably only have about 10 to 15% of the oil synthetic. My friend says that everything is O-ringed on the engine and there shouldn't be any issues. In the next couple years I will slowly incorporate synth until I get to 100% synthetic but I'm still kind of concerned about a rear main seal leak. Good to see nobody's had a problem with an older vehicle switch to synthetic.
Sent from my iPhone using Tapatalk
100K PMs
By grouch0jr in forum General HelpReplies: 3Last Post: 03-24-2011, 12:55 AM -
100k
By Darkrider02 in forum General HelpReplies: 35Last Post: 09-29-2010, 08:26 AM -
Best lux sedan under 100k?
By Murder after Midnight in forum Almost Anything GoesReplies: 22Last Post: 09-22-2009, 01:22 PM -
100k+ help
By FullBlack4thGen in forum Forced InductionReplies: 2Last Post: 07-11-2009, 04:18 AM -
100k...almost
By third_shift|studios in forum Firebird / WS6Replies: 12Last Post: 10-29-2005, 11:36 AM
