Results 1 to 20 of 26
Thread: 2000 Z28 throwing code P1860
05-21-2016, 09:05 AM #1
Looking at buying a 2000 Z28, but wanted some insight on an issue it has beforehand. Owner says he replaced the TCC solenoid as the converter was unlocking at highway speeds. That fixed that problem, but he's had the CE light on for that code since then. What are the most likely culprits for this?
05-21-2016, 05:57 PM #2
Triggers for that code occur when the PCM commands the solenoid "ON", 90 percent, and the voltage feedback remains high (essentially equal to whatever the charging system is putting out); or when the PCM commands the solenoid "OFF", 0 percent, and the voltage feedback remains low (zero volts).
First thing to check is your ENG CTRL fuse - should be a 15 amp fuse in the underhood electrical box. Most of the other diagnostic tests require a scan tool that can command the solenoid to turn on and off, checking wires for continuity and resistance, etc. Have you inspected the wire harness for damage?
05-22-2016, 08:06 AM #3
05-22-2016, 08:13 AM #4
If it turns out to really be a faulty solenoid, you probably have to open the transmission back up and remove the valve body to replace it. Unfortunately, new parts do not always equate to good parts. Could also be an issue with the internal wire harness on the transmission.
05-22-2016, 08:21 AM #5
05-22-2016, 01:26 PM #6
Interesting. When a P1860 code is set, it inhibits TCC engagement, freezes shift adapts from being updated, and can also inhibit 4th gear if it detects "hot mode".
05-23-2016, 09:16 AM #7
05-23-2016, 04:44 PM #8
05-23-2016, 05:30 PM #9
Apparently the PCM still thinks there is a problem. You'll need someone with access to a Tech II or similar to test the solenoid and see what is happening.
05-23-2016, 05:47 PM #10
05-25-2016, 03:03 AM #11
Not if the price is right. Selling the car with the SES light on could be an issue for him.
05-25-2016, 03:20 AM #12
05-25-2016, 05:43 PM #13
How does it seem to you when you drive it?
05-25-2016, 05:58 PM #14
05-26-2016, 03:08 AM #15
I assume you have disconnected the battery or cleared the code?
05-26-2016, 03:25 AM #16
05-27-2016, 03:07 AM #17
If you want me to email you the diagnostic for that DTC, PM me your email address and I can scan it this evening.
05-27-2016, 03:19 AM #18
05-28-2016, 01:44 AM #19
Email sent.
06-02-2016, 01:27 PM #20
- Nov 2007
- richmond,ca
black- 1988 camaro
You sure its not 1870 code component slipping
Sent from my SM-N910P using Tapatalk
Security light always on & code P1860
By Never-Enough in forum General HelpReplies: 1Last Post: 05-21-2016, 05:58 PM -
Throwing MAF code and don't know why...
By SajoR in forum General HelpReplies: 4Last Post: 03-23-2010, 05:03 AM -
NO longer throwing code
By knightryda01 in forum Firebird / WS6Replies: 3Last Post: 09-18-2008, 04:42 PM -
Help: Throwing an Obd code the First day with it!!!
By Justin93 in forum General HelpReplies: 10Last Post: 06-24-2008, 10:20 AM -
O2sims and im throwing a code....
By Liveforfunjim in forum Computer & TuningReplies: 3Last Post: 07-11-2007, 01:43 PM
