Results 21 to 40 of 40
Thread: What should i start off with?
12-17-2015, 02:45 AM #21
The coolers generally come with fittings, hoses, clamps, and a method of attachment. I elected against the B&M stacked plate design due to the angle our radiators are laid back. Seemed that a tube and fin style cooler would have better air flow through it.
12-17-2015, 03:20 AM #22
The Hayden trans cooler I have would be overkill for just a mild build. The cooler I have is made for extreme heat applications. Drag racing, road course racing, turbo's, blowers etc. A bunch of guys running big turbo's use the same cooler. You can't go wrong with this one, just probably don't need nothing this big. Although if in the future you wanna upgrade to forced induction, you are good to go. It never hurts to have less heat in the transmission. It does come with everything needed to install. Fittings, hose clamps, wire ties, mounting zip ties, etc. You can't go wrong with it.
1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
12-17-2015, 09:22 AM #23
- Nov 2015
- Arkansas
12-17-2015, 09:29 AM #24
- Nov 2015
- Arkansas
The hayden trans cooler you said is 45$, thats a pretty good price. And your saying its really good? Whats the BTU ratings on it?
12-18-2015, 02:46 AM #25
This is our trans cooler installed on the car. Without measuring I can not recall its dimensions, but this will give you a pretty good idea of its size. Trans temps generally stay below 180 degrees while driving. On a hot day, in traffic with the AC going, it'll get up to around 200 degrees which is still well in the safe zone.
12-18-2015, 03:08 AM #26
Bigger is better in general. If you go to Summitracing.com, type in this part number in the "search" box. HDA512. It will pop right up. It has a cooling fan and temperature switch too. I Am not sure what the btu ratings are for it, but I can tell you that in traffic, 100' day, with a blower, 3200 stall convertor, and only a single radiator fan (the procharger set up takes away the twin fans, to make room for the blower head, and replaces with a single fan), the trans temp will on rise to around 210. Under normal conditions, the trans temp stays around 180-195.
12-20-2015, 12:13 AM #27
- Nov 2015
- Arkansas
Alright ive been convinced to get the cooler. But i need some opinipns. Its come to my attention that the 10 bolt is the main factor for ls1 cars.
But my car wont see a drag strip ever. Unless i decide to, than i will sace up for a S60 or a 12 bolt. But for right now the car wont visit a strip. Can anyone send me a link for a built kit for the 10 bolt? Id like to see what all is avaliabe.
12-20-2015, 06:24 AM #28
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
I never have been to a drag strip and mine failed this year. I got lucky mine lasted much longer then most as I did mods. The problem is the gear teeth are too small for our cars hp. 10 bolts are just a time bomb not if but when. It really is true putting money into a 10 bolt is just a waste of time, effort and money. Do yourself a favor either start putting money away for a new rear or put it towards something else.
12-20-2015, 02:17 PM #29
- Nov 2015
- Arkansas
12-20-2015, 11:02 PM #30
So, everyone has already mentioned all the good stuff. But, I would recommend doing some research on tires. Especially if its your DD. I'll tell you: I did my homework when it came to tires, and the swap totally transformed the car. Don't overlook the effects of getting the best tires you can afford and that are purpose built for how you want your car to behave.
Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
12-22-2015, 01:49 AM #31
You can go to Strange's website and shop there, I believe. We run a Moser 12 bolt in our car and beat it at the track whenever we get the chance. The Strange S60 is a beautiful rear that is damn near bulletproof. You can also choose from 9" and 12 bolt options that are all designed to fit our cars. If you are M6 you'll want 4.10's and on an A4 3.73's work real nice. Note that in swapping out the rear you may need a different drive shaft length -- we had to go shorter by around 3/4", if I recall.
12-26-2015, 03:11 AM #32
- Nov 2015
- Arkansas
I ordered the hayden trans cooler man. Hope its worth it!
12-27-2015, 04:36 PM #33
- Nov 2015
- Arkansas
Can anyone tell me which nitrous kit is prefered to get? Id like to get a link of a kit of everything i need to run it safe. Ive decided to buy a kit tax return.
I need as much help as i can so if you guys can list me everything i need to run it safe.
12-28-2015, 05:27 AM #34
12-28-2015, 12:10 PM #35
- Nov 2015
- Arkansas
12-28-2015, 02:28 PM #36
I would absolutely mount it in front of the radiator -- there is really no other area with unrestricted airflow.
12-28-2015, 03:12 PM #37
- Nov 2015
- Arkansas
12-28-2015, 05:42 PM #38
Unless you bugger something up in the installation process, not at all. I have had a trans cooler mounted in front of the radiator on our Suburban since we bought it in 2010, and one on our F-body for about the same period of time. Zero issues on both.
12-28-2015, 06:12 PM #39
- Aug 2007
- Greensboro, NC
Sorry just saw this.
Got mine from central racing parts. Owned and run by a guy named Carl spent a good hour on the phone talking to him about all my options and what would be best for me. For the price at the time it couldn't be beat. Came straight from strange ready to go just needed to unbolt and drop the 10 bolt and bolt in the new s60. The only thing you have to do is send them your backing plates off your 10 bolt.
12-29-2015, 08:50 AM #40
Help: 97 TA won't start
By ADAM-00SS in forum LT1Replies: 7Last Post: 07-08-2010, 03:13 PM -
Z28 won't start
By flaggs_ls1 in forum General HelpReplies: 4Last Post: 05-11-2008, 08:46 PM -
where to start?
By Jane_says in forum Firebird / WS6Replies: 47Last Post: 02-25-2007, 08:14 PM -
Cold Start/Warm Start Problem
By I'mLS1John in forum General HelpReplies: 11Last Post: 02-23-2007, 07:11 PM -
By I'mLS1John in forum New Member IntroductionsReplies: 0Last Post: 02-22-2007, 05:26 PM
