Results 1 to 19 of 19
Thread: Upper dash trim
09-01-2015, 01:51 PM #1
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
Upper dash trim
Does anyone make a repro upper dash trim, the flat peice up against the windshield that cracks with age? I just got a small crack near the thin part of the vent/security bulb. I've seen the vinyl covers but dont know how flush they are, nor if the trim keeps cracking, if the cover will stay as it should.
09-01-2015, 02:05 PM #2
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
I have not seen any repros yet. I bought NOS one about a year or so ago and it was slightly over 400.
09-01-2015, 02:08 PM #3
- Aug 2007
- Greensboro, NC
The vinyl ones are ok but you can tell its a cover but it's not super obvious if you get a decent made one and install it correctly. I just wanted it be a real piece which is why I bought a new one.
09-01-2015, 07:20 PM #4
09-01-2015, 07:36 PM #5
- Aug 2007
- Greensboro, NC
Yeah I've seen some guys over on tech take some completely shattered ones and rebuild them using epoxy and then cover them in either a leatherette or vinyl material. Looks pretty good but alot of work. A small crack probably would be pretty easy and you can possibly reinforce the rest and keep it from getting any worse.
09-02-2015, 04:18 AM #6
- Sep 2010
- Bel Air, Maryland
What are you thinking as far as reinforcement? Maybe a layer of epoxy on the underside? I plan on using what some people call "45 minute glue", its an epoxy that body-shops use to adhere large panels to the cars body and hold it in place so they can do the welding more accurately.
09-03-2015, 09:43 AM #7
I would try plastic welding first over epoxy.
Not hard to do but you need to make sure you don't burn through. All you need is a soldering iron and some donor plastic material similar to the pad.
I've made a few repairs to plastic items using this.
09-03-2015, 11:36 AM #8
09-03-2015, 12:28 PM #9
Here is a thread on an air lid I've been working on. It will show you the basics.
http://www.ls1.com/forums/f63/airlid-repair-181652/
09-03-2015, 01:18 PM #10
- Sep 2010
- Bel Air, Maryland
I put pix of the crack in my album. I will try to do it here after I get home. Its pretty small in damage and size compared to what you did.
09-09-2015, 03:59 PM #11
- Sep 2010
- Bel Air, Maryland
This is what I am looking at, would it be too small for "plastic welding"?:
http://www.ls1.com/forums/members/wh...dash-crack.jpg
09-21-2015, 06:34 AM #12
- May 2012
- Dayton, Ohio
Black & pewter- 2002 Formula & 1999 TA
Keep in mind a small crack is going to get bigger.
09-21-2015, 06:47 AM #13
09-24-2015, 06:08 AM #14
09-24-2015, 06:34 PM #15
Eastwood makes a nice plastic welding kit: TPO, TEO & PP Plastic Welding Kit
09-28-2015, 10:20 AM #16
- May 2012
- Dayton, Ohio
6litereaterdesigns.com has a reproduction dash pad for $190 plus shipping. That might be what you want.
09-28-2015, 01:34 PM #17
09-28-2015, 01:37 PM #18
09-30-2015, 09:08 AM #19
Wanted: 98 upper dash
By Justin23454 in forum Parts Wanted / TradeReplies: 1Last Post: 09-19-2010, 07:39 AM -
Upper Dash for 99 Camero SS Help...
By in4sit in forum Appearance SectionReplies: 1Last Post: 07-12-2007, 05:37 PM -
shifter boot, 98-02 upper dash
By jm1841 in forum Parts Wanted / TradeReplies: 0Last Post: 05-01-2007, 09:56 PM -
Dash Pad Needed (upper Dash)98-99***
By LETHALxLS1 in forum Parts Wanted / TradeReplies: 3Last Post: 01-20-2007, 11:10 AM -
WTB upper dash pad
By IDOL of AMERICA in forum Parts Wanted / TradeReplies: 0Last Post: 01-07-2006, 06:07 PM
