Results 1 to 10 of 10
    Purcellville, VA
    Server Issues/Low FPS/High Ping NEED HELP!!!
    OK....so I'm an admin on eGo (Edge Gamers Organization). Lately I've been having serious issues with low FPS and extremely high ping while playing Battlefield Bad Company 2. I've never had problems before, even though the server is located in Dallas TX. For some reason over the past week it's been so bad that I can't even play. Any thoughts of what might be going on or what I could do? The ping will go to 999, drop back to the mid hundreds, drop lower to where i used to play (103 or so) and then shoot back up to 999. FPS gets worse when the ping goes up.
    I've tried EVERYTHING....virus scans, uninstalled updates, tracerouts, ping tests,etc. Comcast says this is not on their side. Internet connection looks good and I've tried resetting/turning the router off numerous times. I know ZILCH about computers.
    Centerville OH
    blue
    1999 TransAm
    - did you attempt to isolate the router by just plugging the computer directly into the modem?...
    - ethernet cable could be bad, try another one..
    - could try updrading to a newer driver for your computer's NIC (network interface card, i.e LAN connection)...
    May 2013
    Nashville, TN
    Black / White
    '00 T/A M6/'19 Hemi Truck
    Quote Originally Posted by cam02ss View Post
    Can you run a continuous ping and see if it's dropping packets or if it's spiking at a certain point? Just run a continuous ping on the server IP address and see what it does.
    06 Quad Cab HHHHemi - Sold
    97 Camaro - Sold
    Purcellville, VA
    The server IP address is listed as 74.201.57.195. I ran a ping test using Website speed test and the result was 152 MS. I'm assuming that's high because they stated anything lower than 50 MS would show up as a green bar. Anything over- yellow. These were all yellow.
    May 2013
    Nashville, TN
    Black / White
    Ping 8.8.8.8 and tell me what you get.
    FYI...8.8.8.8 is Google's DNS server so if you get a high ping on that one it's something either on your ISP's end or yours but we can narrow that down as well. Just need to get some base info.
    Purcellville, VA
    Sounds good, I will try that when I get home from work this evening.
    Purcellville, VA
    Just ran the test, came back 3 MS. Went out and bought a new coax, Ethernet cable and tried to hook up to the cable port in my room. Apparently it's off so Comcast is going to come out Friday afternoon and hook it up. We'll see if running Ethernet directly from the router to the PC does anything. If not, I would guess that it's on the server side?
    May 2013
    Nashville, TN
    Black / White
    For some reason I didnt get an alert that you responded to this thread...sorry about that.
    But yes to answer your question if you run an ethernet cable straight from the router or modem to your PC and you are stilling getting latency issues that is more than likely the server issue and not your connection.
    3 MS pinging Google's DNS server also makes me think its the server your connecting to because thats a pretty normal ping time compared to what you were getting and all you changed was the address that you were connecting to. If it was your connection you would have still received a high ping.
    Purcellville, VA
    Comcast came the other day, running off the router now and everything is fine. Not sure if it was the wifi, or the cable...but gaming is back to normal now lol. Thanks for the input! The server does lag sometimes..there are a few people on the forum mentioning that.
    Oct 2020
    Tampa, FL
    Damn! Comcast has been doing this for years. Bad service, indeed.
  1. idle issues... idle high. unplugged tps runs good?
    By okiels1 in forum Firebird / WS6
    Last Post: 12-31-2016, 03:36 AM
  2. Ping maybe knock?
    By jetaws6 in forum Internal Engine
    Last Post: 09-27-2010, 04:39 AM
  3. Gm high tech performance back issues
    By 02fbody35th in forum Camaro / SS
    Last Post: 06-02-2010, 04:52 PM
  4. Question: engine ping
    By 02fbody35th in forum Internal Engine
    Last Post: 02-20-2010, 08:33 PM
