Results 41 to 60 of 66
Thread: p0300, ruh roh!
10-23-2015, 05:10 PM #41
- Oct 2015
- Francis
White- 96 chevy
Motor went out locked up we installed this used motor and have been having this trouble ever since. Used motor has 110000 I believe 145 compression don't have the sheet in front of me we ran bg injector cleaner in it hoping it was a couple injectors a little dirty Then swapped out the entire injector rail
10-24-2015, 04:17 AM #42
Checking my manuals, the diagnostic for a P0300 starts with performing a CKP System Variation Learn Procedure. It appears that this has to be completed utilizing a Tech II. The procedure involves plugging in the scan tool, enabling the learn procedure, warming up the engine, and slowly raising the rpm to 4,000 and then immediately releasing the throttle. The engine is then turned off for no less than 15 seconds to complete the learn procedure.
The remaining diagnostics all focus on O2 sensor output, vacuum leaks, engine grounds, injector wiring harness, fuel pressure, fuel contamination, and restricted exhaust (ie. a bad catalytic converter). Have you checked fuel pressure with the revs up?
10-24-2015, 04:20 AM #43
- Oct 2015
- Francis
White- 96 chevy
We had the Chevy dealer do the relearn made no difference also checked for updates checked fuel pressure it is good
10-24-2015, 05:27 AM #44
Back of the intake where the MAP sensor plugs in is leak free? The vacuum "T" back there and associated lines all good? Have you done a spray test around things?
10-24-2015, 05:53 AM #45
- Oct 2015
- Francis
White- 96 chevy
Yes checked that oring sprayed test a few times
10-24-2015, 06:29 AM #46
So, if you unplug the MAF the problem completely goes away?
10-24-2015, 06:36 AM #47
- Oct 2015
- Francis
White- 96 chevy
Correct with a mass airflow unhooked the scanner will not pick up a single misfire with it unhooked he had a rough idle but that's pretty normal for not being hooked up but no misfires
10-24-2015, 07:25 AM #48
- Oct 2015
- Francis
White- 96 chevy
Just changed cam sensor no difference took off both belts just for the heck of it no diffrence
10-24-2015, 07:52 AM #49
What year was the engine you took out and what year was the one you installed?
10-24-2015, 08:32 AM #50
- Oct 2015
- Francis
White- 96 chevy
2001 is the one we took out not sure right now of the one we put in don't have the sheet with me of the 1 check sometime supposed to be the same same engine code is there a difference
10-24-2015, 09:48 AM #51
Yes - depending upon the year they can have different cams, injectors, intakes and heads. Could be as simple as a tuning issue.
10-24-2015, 09:55 AM #52
- Oct 2015
- Francis
White- 96 chevy
Same here what is the Sahara and one is a Silverado only difference
10-24-2015, 11:48 AM #53
- Oct 2015
- Francis
White- 96 chevy
Sorry dang autocorrect it's a same year only difference is one is A Sahara in one is a Silverado
10-24-2015, 01:56 PM #54
Ok -- chances are that they are in fact the same engine then.
10-24-2015, 01:59 PM #55
- Oct 2015
- Francis
White- 96 chevy
Yeah where lost pull valve covers next week
10-25-2015, 12:07 PM #56
- Sep 2014
- Pittsburgh
Black- 2001 Camaro SS
I was never able to figure mine out. Haven't done quite the level of troubleshooting you have Tbocambridge. I moved away and mine's sitting in storage for the last year, no chance to work on it. But it sounds exactly the same. I recall disconnecting the MAF and not seeing any misfires. Put a new MAF on and they came right back. Please keep posting though. I will be getting back into mine over the holidays and your posts will be helpful. Hopefully one of us gets it figured out!
10-25-2015, 12:30 PM #57
- Oct 2015
- Francis
White- 96 chevy
Thanks and yes we will be sure to post what ever when ever we find it out
10-26-2015, 10:43 AM #58
What wires and plugs are you guys running? Plug gap?
10-26-2015, 10:56 AM #59
- Oct 2015
- Francis
White- 96 chevy
Factory wires first then Napa premium I don't remember the gap but if that was the case shouldn't it be on other cylinders as well
10-26-2015, 10:59 AM #60
- Oct 2015
- Francis
White- 96 chevy
Haven't pulled the valve covers yet either going to do a leak down test first and also looking for a local ecm to swap out
P0300 on Highway cruise
By redbird555 in forum General HelpReplies: 4Last Post: 06-02-2011, 07:15 AM -
P0300
By 77k5 in forum LT1Replies: 2Last Post: 05-25-2010, 12:31 AM -
P0300 Code - HELP
By oldguy in forum GM TrucksReplies: 1Last Post: 09-05-2007, 05:33 PM -
code P0300
By neverlate in forum External EngineReplies: 9Last Post: 06-04-2006, 06:58 AM -
Need help with P0300 misfire
By Doc99SS in forum Computer & TuningReplies: 2Last Post: 10-24-2005, 07:05 AM
