Thread: LQ9
    Aug 2014
    red bluff
    LQ9
    Was wondering if anyone knows the gas mileage for a LQ9 bored to a 408 and does it run hot. Would u recommend it for a every day hot rod driver
    The more power you make the more heat the engine generates. This being said, there are a couple of guys running 4-oh-whatever displacement engines in their F-bodies with no cooling problems that I have heard of. Shouldn't be an issue in a truck with the frontal area and larger radiator setup. You can swap in a cooler thermostat and reprogram the fans to come on sooner. The stock thermostat in most GM's are around 198 degrees these days.
    Gas mileage all depends on your right foot and final gearing. With an overdrive transmission you should be able to easily keep it in the mid-teens.
    Junior Member Wagonmaster2's Avatar
    Aug 2011
    Loganville, Ga.
    black cherry
    1939 Chevy
    I know of two here locally that do not have overheating issues. I have a 6.0, but mine is stock bore and stroke.Click image for larger version.
Name:	39 cruising to Winder.jpg
    98 T/A w/ mods, 00 FBVert
    Mine is a 403ci. No issues with cooling what so ever. I have a 165* T-stat, and do have the fans come on around 190*. I live in South AL where temps get in the high 90's to 100's in the summer. Still no issues.
