Results 1 to 2 of 2
Thread: 1999 Trans Am not starting.
09-09-2012, 01:41 PM #1
- Sep 2012
- alabama
Navy Blue Metallic- 2000 Z28
I bought a 99 TA with the broken starter mount issue. It supposedly was a rebuilt engine(it is clean with all new gaskets, and some sensors) Guy I got it from said he thinks he didnt tighten starter all the way and was spinning it over after installing engine and block broke. I had the starter area on block fixed and installed the truck starter.(I have a guy local to me that did an AWESOME job Tig welding the block in the car). I have a 2000 Z28 that I have owned since it had 3 miles on it, but have never ANY issues out of it so I'm kind of a rookie at something this involved on a LS car. I have spark, injector pulse, strong fuel pressure at the rail(don't know psi but it comes out strong) Car cranks over fine and has 120-180 psi on all cylinders(kinda low on a few,but engine has never been ran, and it should fire with at least 100) I have checked to make sure cam and crank sensors are plugged in as well. I am at a loss. Any thoughts? Not really new to the site but its been long enough I could not remember my user name.
09-10-2012, 08:25 AM #2
Glad you were able to fix the starter block.
Fuel, Air, Spark, Tune....these are the 4 things need for a fuel injection engine to run.
Fuel - You've checked the fuel pressure, but have you checked the injectors (FI)? FI's can fail because of electrical issue (no pulse to inject fuel) or fuel flow issue (bad injector, gunked up from sitting, etc..) Point being - they need to be checked too.
Air - simple
Spark - Seems you've already check this area.
Tune - You said it was rebuilt, was it rebuilt by him or a shop? I put this here because if the timing chain is incorrectly installed then your timing could be completely off. This effects the the PCM.
Can you shoot a video of it trying to start and post it? This could help a lot.
Also where in AL are you?
1996 Trans Am WS6 Not Starting
By Blackhawk96 in forum LT1Replies: 7Last Post: 05-19-2013, 11:24 PM -
need help with 98 trans am not starting
By wnarunm in forum General HelpReplies: 6Last Post: 01-25-2013, 03:51 PM -
Trans am Starting issue, Fuel Pressure Regulator?
By mrfriendly23 in forum General HelpReplies: 4Last Post: 04-13-2010, 06:26 PM -
1999 Pontiac Trans Am SLP Performance Parts Test - Trans Slam
By Ed Blown Vert in forum GTOReplies: 0Last Post: 09-29-2007, 06:50 AM -
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 08-29-2007, 03:10 AM
