Results 1 to 20 of 28
Thread: How to Install sfc?
09-02-2011, 01:50 PM #1
How to Install sfc?
Ok so umi is haveing a sale on the three point sfc's I was just wondering how hard are they to install? Iv seen pictures of them installed bu does the supension need to be loaded? any details and pics of the install process? Thanks in advance
09-02-2011, 02:15 PM #2
- Oct 2008
- Coral Springs, Fl
Suspension should be loaded for the install, most people put the tires on ramps or you could put the rear axle on jack stands.
Install shouldn't be that bad as long as you got the right tools haha
As a matter of fact ordered myself a set of umi 3 points a few hours ago
09-02-2011, 03:57 PM #3
But wouldent the rear lca's be loaded if the supensions loaded? So how would install them?
09-02-2011, 04:30 PM #4
- Oct 2008
- Coral Springs, Fl
Just do one side at a time and you should be fine
09-02-2011, 05:40 PM #5
I knocked together a set of wooden blocks to set the car on as I have a 2 post lift. Just be safe however you do it. Like Tater said, do one side at a time and you will be fine. It is a simple install -- my 2 point UMI bolt-ins took all of 20-30 minutes.
09-02-2011, 08:04 PM #6
Do I just need the rear wheels loaded or the front and back?
09-03-2011, 03:43 AM #7
The car has to be in the air with the weight on all four wheels. As posted, a set of ramps under the front tires and jackstands under the rear axle will accomplish this. The rear axle is a solid unit, so jackstands are the same as having the car on its rear wheels as far as the suspension is concerned.
09-05-2011, 07:02 AM #8
- Dec 2005
- Pa
Like Jeff mentioned our bolt in SFC's only take 20-30 minutes tops, either 2-point or 3-point. It will take you longer to jack your vehicle up and safely secure it then it will to install the SFC's. The bolt in styles require no drilling or cutting, they are direct bolt ins and include all hardware. I hope this helps!
Ryan
09-05-2011, 07:41 AM #9
Thanks I ordered your 3 point yesterday and am looking foreward to getting them in the mail
09-06-2011, 10:45 AM #10
- Jun 2010
- Central Florida
Navy Blue, Dark Cherry- 98 M6 TA, 87 A4 TA
correct I purchaces and installed the 3-point SFC and tunnel mount Torque arm at the same time, 3-point SFC were not bad, i'd say i spent 30-40 minutes on them. Rear end on jack stands front end on ramps.
Now getting the 3-point SFC and the tunnel mount torque arm with DSL all lined up and the bolts to go through it all and into the bolt holes while my POS exhaust was pressing on the DSL that was not fun...lol, but that was just my car being difficult.
09-08-2011, 05:32 AM #11
- Jun 2011
- Branchville, NJ
Is it better to weld in SFC or bolt them is ? What is the advantage and/or disadvantage ?
09-08-2011, 09:22 AM #12
Weld in are permanent and tend to be stronger in that you do not have to worry about a bolt backing out because it wasn't torque down properly.
Bolt in's gives the purchasier the option of doing it in his home garage and then weld on at a later time. There are some ppl that are willing to remove them and move to another car if they sell it.
For Hard Tops & T tops 3 points are > 2 points > nothing
for Verts - 2 points are the only option at this time. UMI is supposedly working on a 3 pt setup for verts
3 pt are great for autoX racing, drifting, as well as straight line racing & DD.
2 pt are good for straight line racing & DD.
09-08-2011, 09:27 AM #13
UMI just came out with the 3pt for verts. Saw them about a week ago.
LS6 Intake, LS6 VCT, E^2 Catch Can, Hooker LTs and ORY, Magnaflow Cat-Back, 3" QTP electric cutout, UMI adj LCA, PHB, 3 pt SFCs, STB, MGW Shifter, SLP lid and bellow, Free-Mods, Tuned by BlueCat
09-08-2011, 05:15 PM #14
- Jun 2011
- Branchville, NJ
It looks like I will go with the 2 points since I do a little drag racing but no road racing.
09-10-2011, 10:44 AM #15
My three points are in came in a few days ago but its gona be at least a week from today before I will be able to get them put on but I will post pics ass soon as their on
09-14-2011, 07:40 PM #16
09-18-2011, 02:29 PM #17
Got em on yesterday the most stressfull thing was getting the car on the lift we were lucky enough to be able to use my fathers works lift but its for firetrucks and clearence was o so close
11-20-2015, 06:00 AM #18
How do the 3 point work with a x pipe true duals? I just see these installed with y pipes
11-20-2015, 07:51 AM #19
Not a clue - I would check with each manufacturer before committing to 3 points. I know that most of the tunnel mounts are exhaust specific, but there are no options for the 3 points that I am aware of.
11-20-2015, 09:01 AM #20
How to Install sfc?
my buddies 3 pts no issue. the drive shaft safety loop you'll have one. look at mwc for their safety loop. it tucks up in the tunnel and clears all exhaust.
00 FB Vert - Stock
2002 Firebird Trans Am / Install 7.5-7.625-4:10 gear install
By Buick455 in forum Automatic TransmissionReplies: 3Last Post: 07-09-2015, 05:17 AM -
Griffin radiator install, stand up radiator install
By 02Sweet in forum External EngineReplies: 12Last Post: 06-03-2012, 05:00 PM -
Install shop or DIY header install?
By dethinboots in forum External EngineReplies: 7Last Post: 09-24-2011, 06:35 PM -
Install help
By ChadSheehy in forum General HelpReplies: 5Last Post: 05-04-2010, 05:43 PM -
Bayarea...Nitrous install? recommend me a shop or member to do the install? Price?
By 2klude in forum Western MembersReplies: 5Last Post: 04-11-2007, 09:30 PM
