Results 6,921 to 6,940 of 7102
09-03-2020, 05:48 PM #6921
- Mar 2015
- Fl
Done installing the power antenna. Also, my new Nitto 555G2's were delivered today. I ordered these tires from 4wheelonline.
09-05-2020, 04:06 AM #6922
Aftermarket antenna setup or stock replacement?
09-05-2020, 06:20 PM #6923
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
Finish led using the 25 sq. ft. of Fatmat that I bought for the trunk, almost did all of it too. Now I have another 75 feet of it coming, along with a new trunk weatherstrip (it’s beat).
Gracie will get quieter, come hell or high water!
I am smelling some gear oil but I think some must have made its way on the exhaust.
Looked at my winter tires today, after 5 years, I think they are done, might just buy some Grand Touring style all seasons as their replacements
09-10-2020, 05:26 PM #6924
- Mar 2015
- Fl
09-11-2020, 06:01 AM #6925
09-12-2020, 02:44 AM #6926
Real muscle cars are supposed to be loud, hot and uncomfortable.
09-15-2020, 06:36 PM #6927
Ordered my rear sway bar from UMI. Going to be 4-5 weeks till it ships.
They're backed up from the BS virus....so I can wait....
Also ordered some tow hooks from CBRPerformance to mount on the rear to assist in tie down of the bird when the trailer finally comes in.
09-15-2020, 06:53 PM #6928
Man, you got that right about the BS virus. Watch, it will all be over with after the elections....And Trump wins AGAIN!!!! Sit back and watch! I got in some new rod ends for my panhard bar. Had to buy 5/8" bolts and will have to drill out the bolt holes, but it should make tolerances tighter and not allow so many rattles. I shook the body from side to side after I took the panhard bar out totally, and it was quiet as a church mouse, the way I'm expecting it to be after replacing the heim joints with the rod ends! Will send pics later.
Ported/Polished throttle body, Lingenfelter launch module, SLP line lock, QTP exhaust cutout, LS7 clutch, K&N, Ceramic coated longtubes, no cats, 3" exhaust, Flowmaster "B", Eibach springs, Midwest Chassis 9" rearend w/4.10's
09-22-2020, 10:21 AM #6929
"What did you do with your Trans Am today?"
I stood and looked at in disbelief after some ASSCLOWN HIT IT WITH THEIR CAR!
I will have to source a replacement mirror and also get busy with SMC repair stuff
to make good the fender right up to the point it can all be painted back to match!
I am bloody furious as the guy just shot away never to be seen again! Having said that
I would not be going through my insurance as I would have a big chunk added to my
premium for sure AND, for the next five years the question..... "Have you had any
accidents , claims or convictions in the last five years" ( do you guys get asked this rubbish)
Does anybody have any guides or tips for removing the fender as I will have to to do a proper repair!!
What a pain in the ass!!
09-24-2020, 02:49 PM #6930
- Sep 2010
- Bel Air, Maryland
SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
09-24-2020, 02:57 PM #6931
- Sep 2010
- Bel Air, Maryland
Finally got off of my butt, and installed the Elite Engineering Catch Can that I bought.
The runber on the PCV valve decided to self-destruct when I pulled it off of the hard line; luckily I had a full PVC emissions assembly, new in the bag still.
Came with no instructions and I dropped one of the bolts when I tried to screw it into the head, finally got a new screw and washer and put it on.
After two weeks of driving, it caught about a teaspoons worth of oil. Not sure if thats average or not.
09-26-2020, 03:35 AM #6932
It is higher rpms that really pull the oil into the can. A lot more oil mist flying around inside the engine. On average, I may get an ounce or less out of ours after a weekend at the track. Sounds like yours is doing its job.
09-27-2020, 07:49 AM #6933
10-09-2020, 01:49 PM #6934
- Sep 2010
- Bel Air, Maryland
Stupid ABS Control Module is having one of its valves intermittently sticking. I tested the brakes and they are locking up fairly easy.
GM refused to quote labor on it, parts department said the part is $800.00, and that if the warehouses still have one (said that they showed them but he had doubts).
I’ve only found aftermarket ABS Control Modules for the 4 way ABS with Traction Control.
Getting the impression that I am forked.
10-13-2020, 09:08 AM #6935
Sway bar can in early
Toe hooks on the other hand, order was cancelled. No in stock.
But found more issues. I swear my bird is a vindictive, jealous bitch if any other car gets attention.
The Tick MC has finally It has a life time warranty but it's such a PITA to get it out.....been dragging my ass in doing it because it means I have to clear out the garage to make room.
10-13-2020, 11:39 AM #6936
Bummer dude. I hear ya. If it's not a radiator issue, it's a panhard bar issue, or an oil pressure sending unit issue, or a rack and pinion steering issue. I've come to learn, that if you don't like working on cars, you should not have a TransAm!!!
10-22-2020, 02:06 AM #6937
You guys doing the Fatmat sound insulation, how much weight do you think it is adding to the car?
I have messaged Cpop about doing cam and heads for my car possibly this spring. Lots of money to save up, gonna try and have $4,000 ready and do it all correctly.
Fuel pump upgrade and injectors are in my thoughts currently as I am more than maxed out on both.2000 Trans Am WS.6 M6
SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
YouTube.com/DarrenWS6
10-22-2020, 11:49 AM #6938
Honestly it weighs less then all the sound deadner the car comes with.
10-22-2020, 06:36 PM #6939
10-30-2020, 08:38 AM #6940
- Sep 2010
- Bel Air, Maryland
I am open to a good used ABS unit, hit me a line!
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
