Results 6,781 to 6,800 of 7102
03-06-2020, 11:56 AM #6781
Wow, those look brand spanking new, and with led lights? Sweet. I would love to have the money to replace everything that is worn or faded. Guess what I'm saying is that I would like a brand new factory fresh WS6 MM6 Firebird TransAm!!! With ZERO miles!! What a dream!! Hahaha!
Ported/Polished throttle body, Lingenfelter launch module, SLP line lock, QTP exhaust cutout, LS7 clutch, K&N, Ceramic coated longtubes, no cats, 3" exhaust, Flowmaster "B", Eibach springs, Midwest Chassis 9" rearend w/4.10's
03-06-2020, 04:45 PM #6782
I can't wait to do something LED related with my headlamps. I can't stand the normal color and poor output.
2000 Trans Am WS.6 M6
SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
YouTube.com/DarrenWS6
03-09-2020, 01:25 PM #6783
I wish they made sealed beam headlamps in LED. Ones that you can plug and play, and not have to install in line resistors and LED flashers for the DRL's. I do like the LED color and brightness and the low power draw and the more intense light and their super long life. I put LED's in the map light and trunk light and have been very happy with them.
03-09-2020, 06:05 PM #6784
What did you do with your Trans Am today?
When I did my HID's, LEDs where not on the scene yet or were damn expensive. Now if I was to do again I would do HID's for low and LED's for high. This combo works best.
I made a thread on how to do this.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
03-18-2020, 08:06 AM #6785
So with the pending Zombie virus epidemic I have some extra time to knock out projects.
Installed the UMI Performance 35mm Sway Bar and discovers my pass side boot on the R&P is torn as well as a possible leak from the PS pump........again....what is with these damn things At least it won't kill my alternator
The UMI is 35mm and the stock on is 28mm. Huge difference in driving now. I had some body roll but not as bad as before when I changed the springs and shocks. With the Tower Brace it really has minimal body roll now. So much so that I feel it more from the rear which has the stock sway bar now, which was a little weird at first.
Installed the new led's in the steering wheel controls. Looks great. Now I need to figure out a couple of other lights like the HVAC and door panel lights.
03-22-2020, 05:36 AM #6786
I have LEDs in my front blinkers and side markers and didn't use resistors cause I swapped my flasher to an electronic flasher unit. No hyper flash and it functions great. One of my favorite doings to the car as the response and brightness of LED fascinates me.
I will probably do the LMC truck mod to my headlamps and put LED kits in since I do not want to spent $900 on the projector kit from Black Bird Lighting.
03-22-2020, 08:03 AM #6787
I did the full HID conversion a few years ago. Based on how much stuff has changed and improved I recommend doing HID for Low beams and LED's for the High.
The HID's take a min to warm up while the LED's are an instant on. HID's provide much more light over an area where as LED's are a more focus beam that is why they're preferred for High beams.
I have a how to in the Sticky threads on how to do this.
03-22-2020, 11:14 AM #6788
04-04-2020, 05:53 AM #6789
Here is my install and demonstration video.
04-04-2020, 06:30 AM #6790
Hi Guys...
Firstly, I hope all is well with all of you with this present Corona pain in the a**?!
Now... I peeled the cover off and put a freshly charged battery in place after giving the car
a good clean and polish.
It started just fine and after a few stumbles after such a long hiatus it idled just fine, however
there is a noticeable ticking noise ( possibly you'd call it a tapping noise?) going on.
Cannot remember it doing it previously but maybe it did!? It appears to be ( as you stand at the front)
coming from somewhere fairly central, and forward, but could be very slightly more to the passenger side?
Any ideas guys??? I know these cars have piston slap from cold but I don't reckon it is that. It carries
on after warming up. I seem to remember asking the owner of my previous TA and he said water pump???
Dunno.....
Anyhow... Keep well all of you and here's hoping for a nice simple answer coming my way from one of you!
04-05-2020, 04:54 AM #6791
Go ahead and drive her. Could just be that the standard LS1 clatter seems a bit louder to you as it has been a few months. I wouldn't worry unless it persists or gets louder. Also, a "tick" can sometimes be an exhaust leak - especially if you have aftermarket headers and a fastener has backed off a bit. This noise usually disappears when things get hot (and expand) unless it is really loose.
04-05-2020, 06:10 AM #6792
Jeff,
Thanks...... I did in fact consider it being an exhaust leak but after truing up
the face of a manifold way back on my '64 Buick, it does not quite seem like that "tinkle"
that was going on then but I will try and get a wrench on them to see!
And.... "standard LS1 clatter! I smiled and it helped me think nothing dreadful is going on!!!!
04-05-2020, 08:02 AM #6793
04-05-2020, 05:54 PM #6794
04-10-2020, 06:28 AM #6795
Nice work. I really should swap out the DRL's on our car. The housings are definitely "toasty".
04-12-2020, 06:50 AM #6796
04-12-2020, 01:49 PM #6797
i need to get her back on the road
04-13-2020, 01:42 PM #6798
04-16-2020, 07:21 PM #6799
- Apr 2020
- Pa
New guy here. Today I took off the front bumper cover on my ws6 to fix a couple cracks in the paint, been putting it off too long. Took me 3 beers to get it removed, not too bad. Hopefully fix the paint tomorrow
04-18-2020, 04:39 AM #6800
Our car is still enjoying its winter slumber. May have to wake it up next week as the weather looks like it may take a turn for the better.
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
