Results 6,021 to 6,040 of 7102
04-04-2018, 02:37 PM #6021
All good! It's a tight squeeze but it works. Was worried about the bracket having to be spaced out and having to mess with pulley alignment but the bracket clears fine. On to possibly fabricating a mount for the coil pack relocation. Real estate is tight but should be done in a couple of weeks and off to the dyno! PICS coming when the build is done!
98 WS6 M6 ASC #2647
Forged Custom 408 w/Vortec YSi
04-09-2018, 12:55 PM #6022
04-09-2018, 01:10 PM #6023
Get that map sensor wiring off the header.
Looks real good. Cam?http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
04-09-2018, 01:26 PM #6024
Haha no worries wiring will be tucked away nicely! Cam specs are:
251/263
.651/.651
114 LSA
Should be fun!
04-09-2018, 05:02 PM #6025
04-09-2018, 07:06 PM #6026
- Apr 2010
- Alabama
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
04-10-2018, 01:19 PM #6027
408 LQ9 that was custom build. Last cam was a little small for the amount of air I was moving so trying out this cam to see what happens. Block will be maxed out and the only thing left too do would be to send the blower in to Vortech to have it upgraded to a YSI-B and running E85 after changing out the ECU. ECU is actually next on the list as I'm limited to a 2 bar map and can't go 3 bar. Stupid 98's!
04-10-2018, 01:27 PM #6028
But here's a short rundown of what's in her:
408 CID LQ9
Eagle forged crank and rods
Diamond dished -26cc forged inboard boost pistons
ARP everything, studs for heads and main caps.
Locally machined and assembled at a reputable machine shop
Morel hydraulic high rpm link bar lifters
Cam
AFR 73cc 245 heads
MSD atomic manifold
Nick Williams 102mm TB
FIC 127 # injectors
Vortech YSI blower w/ custom RMCR bracket
Treadstone FMI
Custom intercooler piping
Vortech Mondo BOV
TSP 1 7/8 headers
4" cutout
Kenne Belle Boost a pump
Walbro 450 pump
Alky Control Methanol injection with 2 15# nozzles
04-10-2018, 01:33 PM #6029
That's a nice build
04-14-2018, 08:29 AM #6030
Ordered a bunch of parts for the car (repairs/maintenance only.... sadly).... And I was hoping to spend that money on fresh tires... getting low.
Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
04-15-2018, 03:56 AM #6031
Tires are on the list this year for our car. Of course, I said that last year too.
04-15-2018, 07:18 AM #6032
Been on the list since '09, no?
04-15-2018, 07:50 AM #6033
FINALLY ,,, woke the beast from it's looong winter nap Friday now that March finally let go of it's nasty grip well in to April. I need to get a battery tender,, it was totally dead -- charged it up and it seems to be fine though ,, a little air in the tires and off and running !!
'02 Black RamAir M6--Kooks LTH, Magnaflo, Lowered Eibach springs and Bilstien shocks, Tuned By Frost, K&N & SLP box, Smooth bellows, polished TB, Spohn perf. suspension, shock tower brace. UMI 3point SFC. Front & side splitters w/ canards. American Racing 18" wheels & Mich. Pilot SS titres
'76 LagunaS3 - 355ci , 350 turbo, 3:55's
04-15-2018, 08:50 AM #6034
I was able to finish up my power steering cooler project yesterday. Decided to fire the car up for the first time since putting it away. Ran the car up to operating temp in the garage. Big mistake. Pretty sure I gassed myself. Doors were closed, no fresh air. The fumes (and who knows what else) really got to me. Nausea, headache, dizziness...nothin' to mess with Bet I don't do that again.
04-16-2018, 07:57 AM #6035
For shits and giggles I showed my ugly bird in a local show mostly because it's a thumb in the eye to the Mustang Fan club that seems to try to take over every yr. Took 1st place in 90's-00's modified class. Beat out a 03 Vette and 00 Civic, the rest were lifted trucks mostly and a couple of Mustangs.
I don't give much props to someone that buys his car, does nothing to it and then shows it over someone that does the same thing but goes out and does some upgrades. If I wanted to see a completely new car I would walk a dealership. It's totally a different thing for a car to stay stock for 20 plus years vs one that's less than a yr old.
Am I wrong?Last edited by SMWS6TA; 04-16-2018 at 08:01 AM.
04-16-2018, 09:24 AM #6036
It's Alive!!!!!!!
Here's a link to a video. Base just to get the car started and warmed up but could not get her to idle because she was dumping waaaaay too much fuel! Dyno in a couple of weeks to get her tuned!
https://drive.google.com/open?id=1q5...XuVCErWZ0VSCZU
04-17-2018, 12:58 PM #6037
Dyno scheduled in two weeks. Gives me enough time to finish up the final things:
-Custom coil bracket to mount the relocation kit. Space is tight so mounting it above the intake where I have a little room left!
-New triple pillar gauge pod. Already have Boost and Fuel Pressure gauges and now adding in an A/F ratio gauge. Using gauge to fine tune the meth ramp up on the fly.
-Installing hood pins. VFN is floppy in the corners. Last thing I need is a hood flying off at speed!
- Waiting on new driveshaft from Strange. Had issue with the u-joint fitment on the shaft they sent me.
That should be it!
Next steps, paint, rearend, tires, and cage. This list never ends!
04-17-2018, 01:29 PM #6038
no kidding on the list.
04-17-2018, 01:35 PM #6039
Allen what pins are you using? The ones I got are too short to use for how thick my WSQ hood is so I'm looking for another set that I could use for in place of the outer rubber hood stops.
04-17-2018, 02:42 PM #6040
Eventually I'll be putting a set of Aerocatch pins when she goes into paint and body but in the meanwhile I'm just using a set of Mr. Gasket hood pins. They are going where the hood stops are. I'll get a pic of it after it's done but eventually I will have the aerocatch's put in
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
