Results 5,781 to 5,800 of 7102
08-23-2017, 01:26 PM #5781
08-23-2017, 05:37 PM #5782
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
Filled up "Gracie" on the way home, another 23 mpg week! I ran the A/C a lot this time, and also had the T-Tops off.
SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
08-23-2017, 05:43 PM #5783
08-23-2017, 05:52 PM #5784
- Sep 2010
- Bel Air, Maryland
Yeah, I guess I need to "purtie" my car up, probably the crack in the door and the rust on the headlight bracket didn't help much, and I think that it is entirely possible that I have more miles on my car than the entire rest of the class had put together .
I did win a door prize of cleaning wipes, so I didn't totally lose out, and I know at least one other person (that wasn't me) voted for my car, so it's a start.
Next years goal, two people that aren't me voting for my car
08-24-2017, 07:37 AM #5785
What did you do with your Trans Am today?
Starting to hate flickr too. What will be a worthy photo hosting site that's easy to get direct picture links. Photobucket has gone by the wayside, flickr is so damn protected I can't share shit and Facebook is out of the question.
08-24-2017, 07:46 AM #5786
another attempt...
...another fail
08-24-2017, 07:50 AM #5787
08-24-2017, 07:51 AM #5788
08-24-2017, 07:52 AM #5789
Let me know if those work
08-24-2017, 07:52 AM #5790
They do. Nice shots.
Sent from my SM-G955U using TapatalkBoost gets you laid, unless your name is Jon.
08-24-2017, 08:46 AM #5791
08-24-2017, 11:20 AM #5792
Flikr doesn't have a direct .jpg link, and to use the /img tag doesn't work. Their desktop site has an embed link, but I can't access that from their app nor from the mobile version of the site (even in desktop mode on mobile). Pain in the ass. Those there I just saved to my phone and uploaded to the site. Should get bigger if clicked on.
08-24-2017, 12:16 PM #5793
- Aug 2016
- oceanside
Silver- 2002 T/A Ws6 convertible
What does that Autotrix do? Make them go down faster? How's the install process?
thanks
08-24-2017, 12:38 PM #5794
- Aug 2016
- oceanside
What does the Autotrix do?
08-24-2017, 12:39 PM #5795
The kit comes with relays and wire harness that bypasses the the factory wiring. The issue is that a lazy GM Engineer ran the + wire to the drivers motor then directly over to the passenger motor. By the time the current reaches the passenger motor it has dropped in voltage for both motors. The charge is weak enough that over time it kills the passenger motor and if you do both sides at same time it will kill the drivers side too. Thus the reason you seem to have to constantly need to replace the motors.
The harness has you directly go to the + post next to the fuse box. You have enough wire to hide it if you choose to. I've done the wire hide mode on both sides of the engine bay and it had plenty of wire to do it that way. You can't even see my hood latch cable.
It takes an hour to do if you have to replace the motor. Print off the instruction photo's with a color printer. He's updated them from when I did mine and it's much easier to see then before. Hardest part is running the wires from the door into the car and then thru the fire wall behind the ecm. You'll need to remove it to pull the wires thru. Not too hard but still a PITA.
WELL WORTH EVERY PENNY!!!! I did mine in 09 and still on both window motors. My buddy over that time period has replaced his motor 4 times. I finally convinced him this last time to let me do it.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
08-24-2017, 04:13 PM #5796
- Aug 2016
- oceanside
ok, cool. Might be worth a shot. But got a few other other things first, like SFC's and rear shocks...:cry2
08-24-2017, 06:23 PM #5797
it's $37
08-25-2017, 03:12 AM #5798
- Aug 2016
- oceanside
got a link or source?
08-25-2017, 03:40 AM #5799
08-25-2017, 06:01 AM #5800
Which kit did you look at? There are 2. One that fixes the power issue the other does that and does the express down like the drivers side?
The power only should only have you running the power and ground from the switch harness thru the door jam into the cabin then thru the fire wall. You should then run it along the passenger fender towards the battery then along the front (I ran mine along the harness that connects the front lights and washer) then up to the red cap that is the + post next to the fuse box.
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
