Results 5,641 to 5,660 of 7102
06-08-2017, 04:55 PM #5641
06-08-2017, 07:17 PM #5642
What did you do with your Trans Am today?
did you check the rear sway bar links
06-08-2017, 11:01 PM #5643
Well that could be the problem ... or it could be a few clowns hiding in there as we have a few of them about at the moment over here trying to get elected to run the country and none of them seem to be talking a good job. In fact we have just had the election and none of the clowns won !!
I think I will go and buy a ton of Dynmat and glue that in there on the passenger side !!
Its all tight and safe under there so will just have to go with it !
06-09-2017, 07:49 AM #5644
06-09-2017, 11:31 PM #5645
Yes that Dynomat is so exspensive..what is made of then.. gold dust ! Its also really heavy by all accounts.
That looks really professional and I bet you can hear a pin drop in there.
SMWS6TA, did you do a write up on the job.. it looks really difficult to get all the interior pieces out ?Kooks LT's /Magnaflow cats/SLP Y pipe. Ed Wright tune. BMR LCA's/Relocation brackets and torque arm. Lowered on BMR/Viking springs. Viking DA coilovers. Baer Claw 14" rotor big brake kit. 19" MRR GT1 rims
06-10-2017, 03:11 AM #5646
I had a good chat with Trevor of SpeedyWS6 fame last night. I am sure you all know him. He is the other guy in the UK with a Trans am..
I even bought my car off of him and we were trying to work out last night how long ago it was !
Between us I think I have worked out this is not going away and it a product of lowering the car with stiffer BMR springs etc. I have the rubber spring isolators in and it sounds like it is coming from there. Maybe the stiffer springs are giving them a pounding over smaller bumps which is what you'd expect to hear. Kind of less annoying now I appreciate what it could be.
I went out in the car just now and to prove the point I got a big pile of dust sheets that I use for decorating (clean of course) and piled them on top of the back seat interior where the spring/shocks are underneath and the noise was far less noticeable.
That brings me nicely onto my next project ..Sound deadening!!!! When I recovered all the seats I noticed there is virtually NO sound deadening on these cars and I would like a "Roll Royce" ride and I ain't gonna get it in my ride with just carpet.
SMWS6TA... that looks like a good job as I said above. AND I can get rattle trap here in London village AND it is cheaper than Dyno mat. What sort of noise were you getting and how much did it cut it down by ????
06-10-2017, 09:18 AM #5647
No write up, it's very easy to remove the pieces. The rear seats a couple of bolts and the front each as 4 bolts. Center consul too. Headliner you got to be careful, it can be destroyed easy because of the age of the material. Only reason I pulled mine was because I needed to recover it in black. Removing the old carpet was easy but at the top of the front foot wells the carpet is held in place by some thick rubber stuff that overlaps the carpet and sticks to the body.
I took me a day to remove and install the FatMat and 1/2 a day to install and adjust the carpet. Once it was in place and I was satisfied, putting the pieces back in was an hour to do.
Road noise is surprisingly lowered when the windows are up. Also no rattle when speakers are turned up. I put some of the FatMat in the speaker pockets and also on the inside of the doors as well.
I ordered 75sq ft to do it all.
06-12-2017, 06:28 AM #5648
It took a like dremil work on the hinges to enlarged the holes but I finally got the hood aligned straight.
I still need to adjust the headlight covers and I'm going to sand down the edge along the drivers side of the hood to get the gap spacing a little closer to what it should be.
I'm fabing a bracket also for the hood pins to mount to.
06-12-2017, 10:04 AM #5649
I'm going to bet than unless you have poly/poly LCAs, then the LCAs are your culprit. I had rod-end LCAs and they clunked ONLY on the little bumps and cracks. When I switched to poly/roto joint, the noise changed (a bit quieter/muffled, but still very noticeable), but still happens in the same contexts.
Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
06-12-2017, 01:37 PM #5650
06-13-2017, 04:44 AM #5651
Nice! I can't wait for my Smoothie to be finished. Hoping it won't be too much of a paint to fit n finish so i can get the car painted.
Also, I picked up a set of factory wheels for $100 to try and save.
A bit of water and 5 minutes with a microfiber did wonders. Can't wait til I get the time to really work on them and see if they will be saved.
2001 Trans Am Vert
06-13-2017, 05:33 AM #5652
Changed my oil yesterday evening - I have been using a synthetic blend but decided this time to go full synthetic. I hope after 111,000 miles, it's ok to do that ?!? I also recently ordered new wheels and tires. Moving up to 18's. Going with American Racing VN425 TT SL and Mich. Pilot SS. I was hoping to have the wheels for the GM Carlisle event but I might've waited to long as they are custom made. I'm going to put some Falken Azenis' RT615's on the stock wheels and Auto-cross it when I can this year. Maybe I'll have them on for Carlisle and participate in their Auto-X shoot-out. That was a hoot last year !!
'02 Black RamAir M6--Kooks LTH, Magnaflo, Lowered Eibach springs and Bilstien shocks, Tuned By Frost, K&N & SLP box, Smooth bellows, polished TB, Spohn perf. suspension, shock tower brace. UMI 3point SFC. Front & side splitters w/ canards. American Racing 18" wheels & Mich. Pilot SS titres
'76 LagunaS3 - 355ci , 350 turbo, 3:55's
06-13-2017, 05:44 AM #5653
- Mar 2007
- Henryetta/Tulsa Oklahoma
Gotta get to a tuning shop as soon as money will allow, and I find a reputable shop around Tulsa (I don't think Ed Wright is doing it anymore )
Something just isn't right with the car. It has some Dr. Jekyll/Mr. Hyde moments. It can be running fine all day, then you start it up, throw it into reverse, and it dies immediately.
Sometimes this will happen 2-3 times, then it will start up and run fine like nothing happened. Like the computer freaks out...then unfreaks out.
Aside from that, it definitely is running rich even when she's minding her manners. Hopefully I'll be able to get some answers within the next month, I have to get front tires for the SS first since it's my daily.
06-13-2017, 05:46 AM #5654
- Mar 2007
Should be fine. I switched to Amsoil full synthetic on my old SS after it had been running blend most of it's life, at about 90k. She was at 232k when I sold her, and 0 issues internally.
I think it's when you go from synthetic back to conventional/blend that you have problems.
06-13-2017, 06:49 AM #5655
Wow SMWS6TA... got all my interior out in half a day.. it was a snip !
I took down the head liner too, the only casualty being the plastic button that holds it up between the T roofs. Must be able to find one over here.
Found loads of small change under the carpet too.. but not enough to pay for the fatmat!
Thanks for the inspiration to do this job..its gotta be worth it !
06-13-2017, 07:15 AM #5656
I took care and the extra time in getting the new carpet right. But so far I can say the liner has made a difference in sound and now that it's getting hotter I'll see just how much it will help there. Not too much I think because of all the glass our cars have. But my wife has confirmed that there is by far much less heat coming from the floor board on the passenger side. That was one of her chief complaints.
06-13-2017, 09:01 AM #5657
06-13-2017, 11:09 AM #5658
06-13-2017, 11:38 AM #5659
06-13-2017, 11:42 AM #5660
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
