Results 5,221 to 5,240 of 7102
08-11-2016, 03:18 AM #52211998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
08-11-2016, 03:23 AM #5222
Man, I cant believe I don't have any pics of my A pillar with the gauges. I have every other picture from the valve covers off installing the duel valve springs and cam, to the fuel pump install. But nothing in the damn car. WTF? LOL
08-11-2016, 05:03 AM #5223
Yesterday the UMI subframe connects got delivered. Hope to install this weekend.
2001 Trans Am Vert
08-11-2016, 05:50 AM #5224
I said the same thing...I was like how the hell I didn't take any?
Remember that the suspension needs to be under load in order to install them. A drive on 4 post lift is best however if doing in in the garage you need to put the jack stands under the axle instead of the body.
08-11-2016, 06:02 AM #5225
I plan to have it sitting on four ramps with all the weight on. I do not have access to a drive-on lift anymore, like I did when I installed my ones on the 96.
08-11-2016, 07:54 AM #5226
Ok just making sure...
08-11-2016, 08:10 AM #5227
08-11-2016, 09:25 AM #5228
Well ask away. Plenty on her that have been down that road.
look in the General Help Section for Tech stickies. lots of how to's there.
08-11-2016, 09:30 AM #5229
Been researching free mods and a tune. Lots of "working" hours have been logged the past couple weeks. Nice having two screens so at least one looks productive if someone comes by.
--Edit: since you said I could ask, just for confirmation on my 2001-- I have no EGR so all I need to delete is the AIR system and that only needs the two plates on the stock manifolds and some kinda plug for the hole in the SLP lid?Last edited by hardtrailz; 08-11-2016 at 09:43 AM.
08-11-2016, 10:57 AM #5230
Yes, I would also pull the air pump fuse till your ready to remove it. IIRC it may pop a CEL, you can get it turn off if you know someone with HP Tuners or Have Frost do it on his mail order tunes.
08-11-2016, 11:04 AM #5231
I am getting the code now occasionally and I think it is due to the hose to the SLP lid being really loose in there. I plan to remove the whole thing like I did on the TB and have it tuned out.
Frost seems to have some busy-ness and longer return times than I would like, but reached out to Mike Norris local and chatted with customls1tuning on a mail-order. I plan to remove the AIR codes and rear O2 as well with any tune.
The only HP Tuner connectin I have does not feel comfortable messing with something that is not his personally and has never done anythng but the truck 5.3s.
08-12-2016, 03:17 AM #5232
Frost is the man when it comes to mail order tunes!! He has tuned my pcm twice (I went from a NA motor, to a blown application) with no issues at all. Goes right through emissions and all. Worth the wait IMO.
08-12-2016, 05:37 AM #5233
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
Also his turn around on a mail order is usually 24 hrs. I've sent him my PCM 3 times over the years to do updates as they happen and never had to wait more than a few days from the day I sent it out..send on a Monday and have it back Friday- Saturday.....USPS FLAT RATE BOX.
99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
08-12-2016, 05:48 AM #5234
Waiting to hear back from Mr. Norris first since he is local, but a week is max i would want the car down. Driving 650 miles per week for work in the truck at half the fuel economy kinda sucks.
Hoping for a chance to "do" something real today that fits this thread and get my subframe connects on tonight. Depends on if the wife has to go in to work or not. On call kinda sucks for me making plans.
08-13-2016, 06:25 PM #5235
08-13-2016, 06:39 PM #5236
No, that's an old pic
Sent from my SM-G900V using TapatalkBoost gets you laid, unless your name is Jon.
08-22-2016, 07:45 AM #5237
- Apr 2010
- Alabama
Almost all the way in. Leaving it a bit loose to install the engine and trans.
Sent from my HTC6535LVW using Tapatalk1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
08-23-2016, 05:04 AM #5238
Put in the UMI subframe connects. feels much tighter
08-24-2016, 06:22 AM #5239
Just scheduled the muffler and exhaust tip swap. Wish i could swing the money for headers and full exhaust, but will have to wait. At least Friday it should have a bit more rumble than stock
08-24-2016, 12:42 PM #5240
- Apr 2010
- Alabama
Why not do it yourself and save the money for headers.
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
